HID HELP!!!
Old Nov 17, 2008 | 02:02 AM
kiss_tc's Avatar
Default HID HELP!!!
I am having a serious issue with my HIDs... I have had them for over a year now, and lately my passenger side bulb has been flickering, like it was going out. It eventually just went out so i decided its time for new bulbs... I bought a whole kit, because a friend of mine had the exact kit and got it for cheap... it was never used so bought it from him... so i replaced the bulbs and it was still doing the same thing.. so i say, ok my ballast is bad, so i replaced them... still did not fix it... then switched the power cord and wires that go from the driver side (factory bulb plug, battery) to the passenger side ballast... so at this point i have replaced everything with a brand new kit, and it still does the exact same thing... here is the weird part... as soon as i turn it on, it works great as it should... 30 seconds alter it flickers and eventually goes out. i can turn the lights off, and back on and they work for a minute and the problem repeats... what is the deal? any input/help would be greatly appreciated! i have checked all connections, fuses, battery terminals, wires, etc... i cant find anything! has anyone else experienced this or know what to check next?
Old Nov 17, 2008 | 02:04 AM
ExpresScion's Avatar
What kit is it? Does it have an inline fuse and relay?
Old Nov 17, 2008 | 02:16 AM
kiss_tc's Avatar
it is kingwood hid 8k... yes inline fuse and relay
Old Nov 17, 2008 | 08:38 AM
datdude1119's Avatar
then its probably the relay, it happened to my old kit twice
check it for water and what not
Old Nov 17, 2008 | 01:42 PM
kiss_tc's Avatar
the inline relay is the little black box in line, right? i have replaced the old one with the new one and no fix? possible both relays are bad?
Old Nov 18, 2008 | 04:20 AM
kiss_tc's Avatar
i took the new relay out, cleaned it up with a wire brush and put it back in, and its much better, but still shakes and goes out every once in a while... thinking about a new relay and going from there
Old Nov 19, 2008 | 03:46 AM
kiss_tc's Avatar
i got a brand new relay today and replaced it, and the light stays on... no more strobing... but it does seem to shake a little bit which never happened before.. any idea what that could be? it is an entirely new wiring set and lights, so im wondering if its just doing that cuz theya re new.. i dont remember if it did that before... the problem as a whole seems to be fixed, just a little shaking thats coming from both lights when im up close to a car or a wall i can see it...
Old Nov 20, 2008 | 02:48 AM
kiss_tc's Avatar
any idea what the shaking would be? i plan to clean up the wires a little bit tomorrow, and try a new ballast and bulb as well to see if any of those would fix it.
Old Nov 20, 2008 | 02:50 AM
kiss_tc's Avatar
also does anyone know if the tc's driver side light is aimed lower than the passenger side light originally? after all of thise staring and noticing small things on my headlights... my pass side light is def aimed a little bit higher than the driver side... is this normal? can it be adjusted?
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
