a quick question.
Old Dec 27, 2004 | 03:10 AM
nshadows's Avatar
Default a quick question.
Ok, so i just recently got my xB and I got a question. I have a manual and going about 80mph my tac is showing 4k rpm. Is this right? This seems high considering in socal I will mainly going around 75mph so thats mid 3k rpm. Should there be a 6th gear or something? lol am I missing something?
Also, I asked this question in another thread but might as well ask again. Can I fit 19" rims on an xB?
Old Dec 27, 2004 | 03:13 AM
Munch's Avatar
Yes that is normal and yes you can fit 19's I have 19's on my Xb with a 2 inch drop.
Old Dec 27, 2004 | 03:16 AM
nshadows's Avatar
gah. thats wierd because a friend of mine has an auto xb and at 80 its barely over 3k rpm's. Does this mean the manual is actually more of a gas guzler then an auto?
thats sicccc btw munch.
squirrel's Avatar
yup, I spin 4k rpm at 80 mph in 5th gear also.
Old Dec 27, 2004 | 03:19 AM
Munch's Avatar
If you want to call it a gas guzler then yes . Thanks for the compliment and that's an old picture of my ride. It looks much different now
Old Dec 27, 2004 | 03:23 AM
nshadows's Avatar
Ok another question. What is the best way to reduce high rpm's at high speed?
Would exhaust and intake increase efficiency ontop of performance? Heh im visiting my parents right now or i would ask my more car savy roommates. sorry for all the questions.
Old Dec 27, 2004 | 03:29 AM
Munch's Avatar
1. You could try to run a taller tire to reduce rpms just a bit, but then your speedometer is gonna be off also.
2. exhaust and intake will give you more power up top.
Old Dec 27, 2004 | 04:31 AM
TheScionicMan's Avatar
Don't worry about it. The car is designed to run there. And yes, the Auto does run at a lower RPM - It's O/D gear is a lower ratio.
Old Dec 27, 2004 | 04:53 AM
squirrel's Avatar
And I still get at least 30 mpg!
Old Dec 27, 2004 | 05:11 AM
Guest
Guest
Posts: n/a
To really lower the RPMs, your gonna have to change the fifth speed gear in the tranny. And whatever gears are hooked up to fifth gear. A nice exhaust will help you out on performance also, its weird how the auto and manual have different rpm readings. The auto is actually louder than the manual with an aftermarket exhaust. Thats why we have axle backs designed for both the auto and manual. :D
Old Dec 27, 2004 | 07:22 AM
UnFocused's Avatar
yes, 4000 rpm seems high. but if i can get 40MPG on an 400 mile road trip going 80 the whole way- then obviously toyota did something right!
Old Jan 7, 2005 | 04:00 AM
badtouch's Avatar
i have a tire size guager on my work computer that show the difference between stock and any size you set over stock, being 185/60 r 15. 18s with 215/35 r18s are about 3% over stock which sets your speedo off by 1 mph at 65 mph. with 19s on 215/35 r19 tires, which is 5% over stock, your speedo is off by 3 mph at 65 meaning its reading 68 mps. just a little fyi
Old Jan 7, 2005 | 04:41 AM
mgithens's Avatar
RPM has very little to do with gas mileage... the biggest contributor to bad gas mileage is excessive acceleration and higher speeds...
for highway driving getting larger wheels will not change your gas mileage... it will most likely reduce your in town mileage because of the reduction in gearing you will make up the difference with more pedal, which translates to more penalty at the pump...
drgonzo92
14
Apr 24, 2019 07:27 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
mc1114
Aug 12, 2015 02:07 AM
goatbelly
Jul 12, 2015 10:13 AM
