Tire Wear Problem
Old Dec 25, 2008 | 06:28 PM
blackcherry07's Avatar
Default Tire Wear Problem
Dont know if it is the right section but i figured that the problem is suspension related so i put it here....
well i have coilovers and was waiting for christmas money to get up on the alignment rack but it didnt make it...
my passenger tire was worn bald on the out side and to the markers on the inside.
driver side is worn to the markers outside and a little shy of the markers on inside
the rears have PLENTY of tread left...
I have - camber and - caster....
i think it is a toe problem and that the passenger tires has serious toe in, and the driver side has some toe in...thes tires wore down from new to bald in about 4 1/2 weeks....definitely not right
also incase it matters i have NITTO NEO-GENS stock specs
Old Dec 25, 2008 | 06:34 PM
XIEmperorIX's Avatar
if your alignment is off enough and you drive a lot 4 1/2 weeks is plenty of time. Your driving habits and road conditions can only accelerate it further.
Also did you check your tire pressure? you may be underinflated
Old Dec 25, 2008 | 06:39 PM
driving habits are good.
i think the toe is off bad on the passenger and moderately on the driver
and yes they are 32psi thats what i thought the problem was so i checked them this morning (cool tires 55*) and it was 31~32psi
also i dont really drive that much i would say maybe 1000 miles since the coilovers were installed...
what could have happened during install/driving to knock the toe in so bad? anything?
Old Dec 25, 2008 | 07:26 PM
well when you lower the car or change the suspension it changes the geometry of the car and your front may have just been more affected than the rear.
When I lowered my car I did my alignment twice. Once right after installing everything and a 2nd time a week or 2 after once everything settled. Of course I was in a brakes and suspension course in college so I did the alignments and installed myself
Old Dec 25, 2008 | 07:46 PM
Checho's Avatar
hmm firestone lifetime alignment FTW!
Old Dec 25, 2008 | 08:13 PM
i know this...but it didnt track badly or have bad camber, so i figured i would wait til i had more money...now i will end up spending way more...
how do you adjust the toe on the tC if my friend can i can get on the rack but i would need to do the adjustments or i have to pay for the techs time...
Old Dec 25, 2008 | 08:16 PM
Well you have to remember everything needs time to settle so when it settled it may have affected the camber.
And to adjust the toe you just loosen up the jam nut on the tie rod and turn it in either direction to toe-in/out..i forgot which direction you need to turn for which but it shouldn't be hard to figure out lol
Old Dec 25, 2008 | 08:22 PM
alright so i need to take out the bolt that connects the tie-rod to the spindle/hub (i believe it is ball-joint) and the coilovers have the bodies notched for camber and they have pillowball mounts so camber will be easy...
anything else i should know emperor?
Old Dec 25, 2008 | 08:30 PM
no you don't take any bolts off. You just loosen it so that you can turn the tie rod. The jam nut is located on the tie rod itself. You loosen that and you'll be able to move the longer nut that's located on the tie rod in order to adjust the toe angle.
I hope that makes sense lol I don't have any pics to show you but once you get under the car you should be able to see what I'm talking about
Edit: Check this out http://blacktc.com/files/tcfrontalignment.pdf
Found this while trying to find a pic of a tie rod to explain what I was talking about haha that should answer all your questions.
This is one of those things I have a hard time explaining but it makes more sense in my head!
Old Dec 25, 2008 | 09:00 PM
o ok i know what your talkng about...
i was just wondering which part i actually rotated but that is perfectly clear to me...thanks emperor....
could i measure the front of tire and rear of tire and get a measurement??
Old Dec 25, 2008 | 09:09 PM
ok according to my measurements i am 7.375 mm out of spec
would this be drastic enough to lead to what i described??
also should i adjust drivers side 2mm and passenger 5mm??
Old Dec 25, 2008 | 10:40 PM
yeah 7mm is pretty off..thats way off.
As far as what you should adjust to I really don't know. I was spoiled with a machine that told me whether i was in spec or not as I was adjusting it lol sorry I can't really help you much more with that
Old Dec 26, 2008 | 01:31 AM
alright thanks man....well hopefully i will have a alignment machine open to me tomorrow for free or very little and i will just use it to try to 0 out the toe...
Old Jan 7, 2009 | 07:45 PM
figured i would come in and bring a conclusion to this thread...
my toe was in .57" on passenger and .22" on driver
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
scionlife
371
Jun 2, 2015 11:00 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
mdhyre
Dec 7, 2014 12:52 AM
jjambox
Dec 5, 2003 12:46 AM
