starting problem
Old Jan 31, 2009 | 12:21 AM
iggy373's Avatar
Default starting problem
I just experienced a weird problem while trying to start my '07 tc, Auto with 21K miles. The car had been sitting in cold for 3 hours and had been warmed up completely prior to parking. I got in, turned the key, and the starter cranked, but the engine didn't turn over, tried like 5 more times, and on the 6th time the engine finally turned and barely started. The RPM's jumped all over the place and it almost stalled out when they dropped really low. I gave it some gas and it stayed running but the Rpm's were still jumpy. There were no warning lights on the IP. It was like that for the first 5 min. i drove, everytime i came to a stop the RPM's were jumpy. Then once it warmed up, it was all fine.
My car has never not started immediately. I have never even heard it crank. The temp was like 15 F but it had no problem starting in -20 F weather and i had a 1/2 tank of gas. Any ideas?
Old Jan 31, 2009 | 03:36 PM
iggy373's Avatar
anyone?
Old Jan 31, 2009 | 03:48 PM
Ace83's Avatar
Ronin Scion
is that starting problem new? If you bought the car used and have no idea how it was before, you might want to check few things.. it could be several things.. bad plugs, bad maf, bad o2 sensor, clogged injectors or something else.. but a well maintained 21k miles should do that unless there is a factory defect. Any mods on the car?
Old Jan 31, 2009 | 04:00 PM
beastC's Avatar
could be your battery. My friends Camry with the 2az-fe does the same thing every once in a while. Once it gets started the rpm's are crazy and it stalls at red lights. But his battery light is on when this happens. Could also be your alternator
Old Jan 31, 2009 | 04:01 PM
iggy373's Avatar
I bought it as a demo from a dealer with 2,600 miles on it. There are no mods.
Old Jan 31, 2009 | 04:03 PM
TwztedtC's Avatar
My car has a hard time starting in the cold but its because of my red top gel cell
Old Jan 31, 2009 | 04:05 PM
Ace83's Avatar
Ronin Scion
battery to might have something to do with it
Old Jan 31, 2009 | 09:02 PM
BlkTC's Avatar
check your battery.. then start looking at the motor which is pretty much what ace83 said earlier...
Old Feb 2, 2009 | 02:55 PM
ATL's Avatar
ATL
My 07 TC started doing the same thing around the same amount of miles last year while it was cold outside (30 – 40 degrees) and just as you explained, it would be at operating temp and I would turn it off for a few hours and come back to it not starting until the 2nd or 3rd attempt.
My problem went away on it’s own a month or two later and hasn’t come back, yet…..
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
BV19869
Dec 11, 2014 06:05 PM
