rough ride
Old Feb 18, 2009 | 08:17 PM
Fawkesthephoenix's Avatar
Default rough ride
HI, i have an 05' tC with a stock suspension and would like a softer much more luxurious ride. What do i need to do?
Old Feb 18, 2009 | 08:23 PM
SW_08's Avatar
luxurious......
i dont think thats gonna happen.....if you want i smoother ride that means you need a different car.....
Old Feb 18, 2009 | 08:26 PM
thereal2x's Avatar
get airbags
Old Feb 18, 2009 | 08:31 PM
Default What suspension setup would give me a smooth ride
So i am needing a better suspension to provide a softer ride. Any suggestions?
Old Feb 18, 2009 | 08:33 PM
SW_08's Avatar
i dont really know what you can do to have a smoother ride....
Old Feb 18, 2009 | 08:35 PM
ilovemytC's Avatar
stock is as smooth as it gets lol
ilovemytC's Avatar
maybe get bigger tires? i ono
Old Feb 18, 2009 | 08:39 PM
lltysonll's Avatar
IMO stock was pretty smooth....but if you want smooth get coilovers ;) just kidding like ilovemytc said "try bigger tires?"
Old Feb 18, 2009 | 08:46 PM
bencott's Avatar
maybe your shocks are showing their age. i noticed that even though i replaced my stock shocks and struts with trd's which have a higher damping rate, the tC seemed more compsed over bumps. it made the ride feel smoother. i think replacing the shocks and struts is the only option short of a coilover setup with custom spring and damping rates.
Old Feb 18, 2009 | 08:50 PM
Big_Bird's Avatar
Well if you wanted a smoother ride, you should have gotten a more expensive car. You pay for luxury. But If you really want to try and get a smoother ride your best best bet is probably going to be airbags. You can try and swap out shocks to something softer, but you're def going tom be sacrificing handling if you do. Just my $.02
Old Feb 18, 2009 | 09:26 PM
ack154's Avatar
OEM suspension is about as soft as the tC gets. You could try new struts if yours are worn out. Or consider a taller sidewall tire. Maybe a 215/50/17?
Old Feb 18, 2009 | 09:31 PM
captainlaziness's Avatar
Put pillows on your seat.
Old Feb 18, 2009 | 09:47 PM
RacheltheTruth's Avatar
^^ x2
the larger the sidewall of the tire, the more "suishy" it is going over bumps.... the tC is by far not a luxury car, nor will it ever drive like one... If you want a smooth luxurious ride, get a buick or a caddy.... tC is not going to give you what you are looking for....
And airbag suspension may do the trick but it is EXPENSIVE.......
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
kb1sxv
Oct 21, 2015 05:00 PM
olyellr
Sep 28, 2015 10:32 PM
prescottn
Sep 13, 2015 09:04 PM
