Roof Spoiler Mounting Question
Old Feb 22, 2009 | 06:29 AM
Batmobox's Avatar
Default Roof Spoiler Mounting Question
Hi guys,
I know this may come off ricey, but I don't mind getting flamed, and I'm still hoping to follow through with it.
A while ago, I bought a used spoiler off of ebay (I know, some of you may already smell the rice cooking) that caught my fancy and I'm finally looking to get it installed. However, the spoiler is made for a trunk of another car (possibly a mustang), and that being the case, I was hoping to mount it to the roof (not the hatch) of the car.
When I brought it up to a friend of mine who owns a body shop, he mentioned that it would be a bad idea, although I'm not sure if its just because he considers the idea too ricey.
My questions are:
1) Would the roof be able to support the weight of the spoiler? My guess is that it weighs at least 20 to 30 pounds.
2) Would it be a difficult endeavor to install the spoiler since it would be on the roof and not the hatch door? (Although I don't see how it would be much different from installing a roof rack.) Is it much different from installing a roof rack? Would the felt (or ceiling cloth) need to be pulled off and re-applied?
3) Would I be inviting a strong possibility for a leaky roof?
The look that I'm attempting comes very close to the spoiler in the link below, although I believe the one I have may be just a few
inches taller.
Any constructive advice would be immensely appreciated!
Old Feb 22, 2009 | 02:01 PM
spr0k3t's Avatar
1) You shouldn't have any problems with the weight at all. The OEM spoiler only weighs about two/three pounds.
2) Installing the spoiler on the roof would more than likely require dropping the headliner. Dropping the headliner is a very easy process, it just takes a bit of time. Roof racks bolt down at the sides are are removable... the wing you are planning to install will be a permanent placement, at least permanent unless you plan on filling those holes later by doing some body work.
3) Your roof will leak if you do not install the spoiler correctly. Make sure you have a gasket for mounting the spoiler and use some form of silicon seal from the bottom of the roof.
Alrighty then. Props for taking the flames man. I personally hate the top mounted spoilers on boxes with a passion. I've never found one that looks remotely decent and their functionality is moot. Anyway, I've spoken my beef. Good luck on the install and post up some pics when you get it done.
Old Feb 23, 2009 | 01:04 PM
swartzautoman's Avatar
the pic you posted is a nice car and the top mounted spoiler is a unique look.
#1 i realy don't think your spoiler is 20 to 30 pounds.
Old Feb 23, 2009 | 03:21 PM
burstaneurysm's Avatar
30 pounds? Doubt that.
Old Feb 24, 2009 | 01:52 AM
Batmobox's Avatar
Sorry, I think I may have overestimated the weight of the spoiler. It's probably around 15 pounds or so. Would that be a problem?
Old Feb 24, 2009 | 02:08 AM
firesquare's Avatar
if you decide to drill it down (because if you double stick it someone will be happy to pull it off for you) make sure you measure twice or 3 times and drill once. take down the head liner and use plenty of silicone.
but i think you need to post a pic of it so we can get a better idea of it. and when you do post it, be prepared to be chewed out hardcore. ill be one of those people if it looks like crap.
Old Feb 24, 2009 | 02:14 AM
Batmobox's Avatar
Thanks for the insight! Actually my car had been involved in a hit and run, so it's getting fixed right now. Both the car and spoiler are at the body shop now, so I can't post pics just yet, but if I do install it, I promise to post them up.
I've got my flame retardant under-roos ready so feel free to flame and not hold back.
Thanks guys!
Old Feb 24, 2009 | 02:18 AM
Batmobox's Avatar
Just for reference, are there any images on SL of other boxes with roof mounted spoilers? I remember seeing the over-customized yellow hotwheels in the Rice and Taters thread, but are there others?
Old Feb 24, 2009 | 01:35 PM
firesquare's Avatar
your not talking about a Mustang Cobra R wing are you?
GOD i hope not.
Old Feb 24, 2009 | 01:57 PM
Batmobox's Avatar
LOL. Nothing that big or tacky.
Old Feb 25, 2009 | 01:40 AM
Batmobox's Avatar
Just to be completely sure, would a 15 pound spoiler cause the roof to warp in heavy wind?
Old Feb 25, 2009 | 03:55 AM
spr0k3t's Avatar
Warpage will greately depend on the mounting structures. If there is enough area covered by the mounts, you shouldn't see any bit of warping. However, it would be good to have some form of extra reinforcement against the roof where you are looking to do the mounting.
I could see a roofmount spoiler looking quite tasteful if the spoiler is designed specifically to fit the box like a glove (like the FAB kit or the OEM kit). Just keep in mind the spoiler could only be for aesthetics more than anything.
Just out of curiosity, is this spoiler a custom made unit or one we can get a picture of on another car?
Old Feb 25, 2009 | 11:02 AM
Batmobox's Avatar
I just rememberd that I did take a cell phone pic a while ago. Of course if I did go through with it, the spoiler would be painted to match the rest of the car. It sits about four inches above the base.
Thanks again for putting up with my repeated questions!
Old Feb 25, 2009 | 01:39 PM
f-k it, just do it.
who cares what anyone thinks anyway.
what realy matters its that you like it.
be original and stand out!
Old Feb 25, 2009 | 01:53 PM
Batmobox's Avatar
Thanks automan! I wanna try it out, just fearful that it will damage the roof.
Old Feb 25, 2009 | 05:11 PM
just take your time, do it right, don't half a5s it, and you shouldnt have any problems.
Old Feb 26, 2009 | 02:01 AM
spr0k3t's Avatar
That actually looks pretty good Batmobox. I'll give you some kudos on that.
Old Feb 26, 2009 | 02:57 AM
bbszero's Avatar
Just use some sort of backing plate on the underside of the roof, at least the size of the base of the spoiler and you should be fine, no warpage.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
umnitza
Dec 1, 2014 06:26 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
