water seeping in to tail light?
Old Jan 7, 2005 | 12:57 AM
dollar5's Avatar
Default water seeping in to tail light?
its been pretty crappy in nj the past few days and i noticed my tail light seems to have a lil water behind the clear cover... but im not sure if its actually in the light housing or just between the housing and the cover. but what really worries me is the fact that the temp is dropping around here and im a lil worried that the water will become ice and ruin the tail lights...cracking or snapping... . should i be worried?
Old Jan 7, 2005 | 01:21 AM
Max2k's Avatar
No, you shouldn't. The riged edge of the tail light housing is separated from the actual lights and the ABS plastic it's made of can flex a bit.
Old Jan 7, 2005 | 01:36 AM
ScionXBrent's Avatar
Mine always gets water in them, even the first time I washed it just a couple days after I got it. Kinda ____ed/____ing me off.
Old Jan 7, 2005 | 02:33 AM
RPMxB's Avatar
Default Re: water seeping in to tail light?
Originally Posted by dollar5
... should i be worried?
Do not be worried... all modern American lighting must pass strict DOT testing to be allowed... even cheap replacement lenses. One of the tests includes moisture build-up. The lenses I have seen dismounted include a little "breathing tube" to allow moisture to evaporate. Your tail lights will be fine. I few drops are normal. :D RPM
Old Jan 7, 2005 | 02:53 AM
Max2k's Avatar
The water is not in your actual tail light housing. There's a slight lip on the lens that fills out the space. The space under the lip is sealed off from the actual light reflectorr/housing by a lot of glue and an interlocking piece of plastic.
Old Jan 7, 2005 | 04:35 AM
UnFocused's Avatar
Yeah, Its 100% normal.....
This is notorious with all xB- the water dosent evaporate as fast in the winter- but dont worry, It got down to 6 degrees last night here and no probs with mine.
The water is not building up in the housing- it is building up in the gap before the housing is sealed. as long as the actual housing - were the bulbs are located- is not fogging up -your ok...
Old Jan 7, 2005 | 08:58 AM
dollar5's Avatar
awesome guys, thanks the the response
Old Jan 7, 2005 | 04:37 PM
Guest
Guest
Posts: n/a
Freaking pine needles like to hide in there and mess up the look. Just flush some water through there and the mess will flow through. Freaking pine needles.
Old Jan 7, 2005 | 05:28 PM
TheScionicMan's Avatar
I saw a 5 series BMW that had half a taillight full of water last night. Just toss a Siamese Fighting fish in there and you are custom...
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
Cadillac15
Jan 29, 2015 07:34 AM
mrbadass03
24
Apr 21, 2004 02:17 AM
randode
16
Oct 1, 2003 12:40 AM
