sub/amp problem
Old Mar 7, 2009 | 09:44 PM
eastham08's Avatar
Default sub/amp problem
My sub stopped working today after about 2 hours of constant use. The amp still gets power but nothing happens. What could be the problem?
Old Mar 7, 2009 | 09:51 PM
DivisionbyZero's Avatar
Does your amp have an overheating indicator? Is the power light a different color, which could indicate that the amp is overheating?
Old Mar 7, 2009 | 09:53 PM
eastham08's Avatar
I don't think it has an overheating indicator light the only light it has is the power light which is red like normal.
Old Mar 8, 2009 | 04:29 AM
wazzu_coug's Avatar
so the sub only stopped? the rest of the speakers are fine? after you've turned off the car for a while, will it start working again?
you did check your fuse first right?
Old Mar 8, 2009 | 04:35 AM
eastham08's Avatar
Yea its just the sub that doesn't work all the other speakers work fine. I had it off today for about 3 hours and it still didn't work.
Old Mar 8, 2009 | 05:26 AM
wazzu_coug's Avatar
can you push in the subwoofer cone? and does it come back out?
can you take your subwoofer out and hook it up to another stereo in another car or in your house? while it might not sound good, sound should come out. this is just to make sure the sub works.
use a multimeter and check the voltage coming out of the amp, (same way you would adjust the gain). if there is voltage, then your subwoofer is probobally fried. if there isn't voltage, then it's probobally your amp.
sounds like you may have fried a voice coil.
Old Mar 8, 2009 | 11:04 AM
datdude1119's Avatar
^^ yeah sounds like a fried voice coil.. while having the music playing.. push the subwoofer in slowly and see if it comes on which it probably will lol
Old Mar 8, 2009 | 04:18 PM
ecko04's Avatar
Bye bye sub...that sucks
Tune your gains a little better next that, use a DMM that will allow a full volume range without killing your sub.
Old Mar 8, 2009 | 07:39 PM
eastham08's Avatar
No sound comes out when I push the sub in. And the gain was barely up, not sure if that makes a difference or not.
Old Mar 8, 2009 | 09:23 PM
eastham08's Avatar
figured out what was wrong. the wire connecting to the terminals on the outside had came unattached some how. Hooked it back up and works fine. Thanks for the help
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
