Autoloc Air Command
Old Mar 10, 2009 | 07:26 AM
my08xb's Avatar
Default Autoloc Air Command
Anyone hear of or have used the Autoloc Air command?? Its a digital controller for air suspension
http://www.vtkustoms.com/Gauges.html#Air%20Command
Old Mar 10, 2009 | 06:42 PM
Just1n's Avatar
Wagonistas
<insert crickets>.... chirp chirp
Old Mar 11, 2009 | 12:13 AM
xBones's Avatar
If I were to go with a digital controller I would go with Air Ride Tech, Air Lift, or Dakota Digital...they've got alot more experience with air suspension than Autoloc. Don't get me wrong, Autoloc makes some good stuff, but they're new to the air ride game.
I had a Dakota Digital guage/controller in my S10, and it was good quality, but the one I had was before they had the ride height sensors. So it set ride height based on pressure, and it wasn't very precise. It would basically set pressure to within 10 psi, which made a big difference on my truck. I'm sure the systems with ride height sensors are much more advanced and accurate.
You can never go wrong with a manual switchbox. I would get one regardless of what digital setup you go with. The digital stuff just isn't as easy to play with, and it reacts slower than a manual setup. You'll run into plenty of situations where you'll need to raise your car really fast to avoid something in the road or when pulling into driveways. Every split second counts. I always rode with my switchbox in my lap just in case.
BTW, that Autoloc setup doesn't use ride height sensors, it goes off pressure sensors like my old Dakota Digital setup. I would recommend going with a basic Dakota guage that reads pressure on the tank and all 4 bags, and use a manual switchbox like this one from AVS.....http://www.suicidedoors.com/air-mana...-rocker-switch...or one of the other various models they make.
Old Mar 11, 2009 | 04:51 PM
ogerdgonz's Avatar
My suggestion is stop the research and try what comes in the package deal you are getting. Then if you do not like it for some reason you can try something else, but I think you will be more than happy with the Digital Controller in the Easystreet kit that you are getting basically for free with the kit.
elwaylite
9
May 15, 2020 07:27 PM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
StxArOne
Jul 13, 2015 06:25 PM
carid
Mar 30, 2015 07:08 AM
eric_m
79
Mar 17, 2013 12:21 AM
