Custom Intake Using Spectre Parts From AutoZone
Old Mar 13, 2009 | 04:35 AM
imageex's Avatar
Default Custom Intake Using Spectre Parts From AutoZone
Spectre intake for 3" intake system for $20
Spectre 3" to 3" or 3" to 2.5" coupler with 2 metal clamps $8
Total: $28 (not including zip ties)
Bought the filter, thinking we had a 3" intake system. I believe now that a filter for a 3.5" intake system would have fit much better.
I used a hair dryer to heat up the coupler, and then stretched it over the MAF, then clamped it down.
The other end of the coupler, attached to the filter,I squeezed inside the filter, which was a tight fit, and then clamped it down also.
I used zip ties to keep the filter from moving around while driving. My concern is that eventually these zip ties will break from tension, or becoming brittle from heat.
I was hoping to secure it in a more permanent way using some metal rods. (Thanks for the rod idea TRDxD)
I have had this setup for about 1 day now, have been checking it a lot, drove a pretty good amount today, and everything is staying in place,
nothing broke, or even slipped/moved the slightest amount.
Hoping to get a Fujita CAI one day, but this setup will do just fine for now on my budget!
Old Mar 13, 2009 | 04:43 AM
imageex's Avatar
Forgot to add, after I installed it all, I unhooked the battery, let it sit for awhile, and it was ALL good.
I wanted to make sure the computer picked up the new airflow, and it did just fine.
Reset all of my settings on my radio, clock, trip A/B, avg speed/mph.
Only thing it didn't reset was the odometer.
I don't think this is even necessary, but I did it anyways
Thanks for reminding me of that
Old Mar 13, 2009 | 04:56 AM
TRDxD's Avatar
dang...very nice pics! haha hopefully i can get mine back and and put the rods on...i really have to stop being lazy and get over to my friends place and work on it! (can't work on the streets where i live and i have no driveway hahah)
glad that i could be of help!! if i finish the rods before you get em on ill post some pics here (if you dont mind) as a DIY
Old Mar 13, 2009 | 05:02 AM
imageex's Avatar
Please do with the pictures! I have a feeling that you will get to it first.
"I made a mounting bracket with a 5/16" rod of all thread, used nylon lock nuts and washers.
took out the rubber grommit on the lower mounting bracket for the air box, bent the all thread so that it lined up with the mounting points for the air box on the back side,
ran rod thru lower mount and put washer and lock nut on bottom,
ran another washer and nut down to secure the bottom to the bracket then put another nut and washer on it and put the intake pipe on the all thread and secured the top, no movement.
One 12" pc of 5/16 all thread, four nuts and washers. cut off excess so that I didn't have the rod sticking out anywhere.
You can do the same for the front, but 5/16 won't fit thru the hole.
If you can find the right metric thread for the front, you could screw it into the front lower mount for the airbox and sandwich the upper mount point between two washers and nuts.
I just finished doing this to mine the other night at work, I'll try to get pics so you know what I'm talking about." Thanks robbiej from Cafe xD
I'm sure that will help you TRD
Old Mar 13, 2009 | 06:25 AM
TRDxD's Avatar
actually thats EXACTLY what i have equipment wise, and exactly what i was going to do to secure everything. thanks for lookin out for me man! I'll try to get it worked out this weekend. im getting an ITCH to work on a car.
Old Mar 13, 2009 | 07:24 PM
xD_kidd91's Avatar
i was goin to go with the red filter but i wanted something with more of a direct flow to it.
Old Mar 13, 2009 | 07:26 PM
TheQuietThings's Avatar
SO what size filter do we need 3"? or 3.5"?
Ace83's Avatar
Ronin Scion
looks clean!
Old Mar 13, 2009 | 07:33 PM
TRDxD's Avatar
mmm i like the stubby :D haha i wanted to go with a dome filter for the hell of it but..couldn't find anything worth the money..(in other words...it was expensive as hell) nor did they come in the diameter necessary
i believe the diameter is 3"...im not sure as to why the 3" didn't work for imageex? but i was pretty certain that it was 3...maybe im mistaken :\
Old Mar 13, 2009 | 09:48 PM
imageex's Avatar
I thought it was a 3" also. The package for the filter said "for 3" intake systems" put when I went to put it on,
it matched right up with the MAF, and did not slid over top of it like it should have.
So maybe the packaging for my filter is wrong, but my guessing is a 3.5" would slip right on, the correct way.
I kind of like the red coupler that it has, and the filter makes a nice, deep tone,
For short, my guess is 3.5"
Old Mar 14, 2009 | 03:00 AM
xD_kidd91's Avatar
my filter is 3" nd i had to do lil slit cut to attach it to the stock pipe. btw dont invest with making your own custom short ram or cold air . not that they are bad but you wont get a good fit with the air fuel adapter and will just cause your car to not start or throw a code. 80 bucks down the drain
Old Mar 14, 2009 | 07:20 PM
imageex's Avatar
Cutting your intake is probably the last resort, chance of leakage.. not good
Old Mar 14, 2009 | 10:10 PM
cobaltbravo's Avatar
did this last year, worked out well. hope it helps.
Old Mar 15, 2009 | 12:52 AM
xD_kidd91's Avatar
half an inch wouldnt hurt plus i clamp it tight.. it been 5 months nd no problem whats so ever
Old Mar 15, 2009 | 01:40 AM
TRDxD's Avatar
Imageex, what cobaltbravo posted is the filter that I got, just to clear it up. I guess different states have different options for their store's...but that was the one haha
Old Mar 15, 2009 | 06:22 AM
imageex's Avatar
That helped a lot, thanks. I think they do sell that filter here,
we only live a state apart, i just went for the cheaper one, which in the in, just didn't fit.
Old Mar 18, 2009 | 03:09 AM
xD_GirL4's Avatar
So then is it safe to say if your going to buy a filter buy a 3" one?
Old Mar 18, 2009 | 03:26 AM
imageex's Avatar
I say buy a 3.5"
my 3" did not fit well, look how i had to make it fit
Old Mar 18, 2009 | 03:30 AM
xD_GirL4's Avatar
If I buy a 3.5" would the clamp tighten enough to make it so no air leaks out?
Old Mar 18, 2009 | 03:32 AM
imageex's Avatar
I am really not sure, i bought a 3" and it would not fit at all, lined up with the MAF,
didn't slide over it, so im guessing that a 3.5" would fit perfectly,
wait till some others respond though, because I am am honestly not sure
