knocking noice?
Old Mar 17, 2009 | 01:16 AM
Degooch's Avatar
Default knocking noice?
So the past couple of days ive noticed a knocking noise in my rear passenger side only. It happens every time i go over a speed bump or down a drive way fast. I checked to see if my lug nuts where loose so i grabbed a torque wrench and a bolt was totally loose
But that wasnt the problem. I havent had a chance to check out my struts lately. Im on htechs and my friend thinks it could be rubbing... But why would it rub on one wheel only?
Oh and i havent had my alignment done yet if that makes a difference lol
Anyone have any ideas?
Old Mar 17, 2009 | 05:23 AM
Degooch's Avatar
yeeeeaaahhhhhh
Old Mar 17, 2009 | 06:57 PM
ihavenosn's Avatar
Check the end links on your sway bar. Sometimes a loose end link bolt can be the cause of knocking.
Old Mar 17, 2009 | 11:15 PM
Scionman09's Avatar
I get this same exact noise..but i was actually thinking shocks..since im still on stock shocks and im lowered..hmm...
Old Mar 18, 2009 | 12:07 AM
Mouse's Avatar
yeah the first two things I'd check knowing that your wheel is on correctly... is the end links...and making sure that the spring itself hasnt slightly moved out of its seat. it's easy to tell with the wheel off if the spring has moved or not. there is a specific seat for it. Thats a somewhat common thing to happen especially if you are running lowering springs on the stock shocks. Because the stock shock has a longer travel than the lowered springs do. So if the shock gets extended say on a bumpy road, then the shock extends further than the spring...making it easy for it to move out of its seat. If this is the case... all you have to do with the car jacked up and wheel off...you can turn the spring by hand back into its seat.
Old Mar 18, 2009 | 03:12 AM
shupes31's Avatar
^^^^ thanks for that tip! the roads around here are horrible and i'll probably have to do that once i lower my 4x4
Old Mar 18, 2009 | 03:14 AM
Mouse's Avatar
no worries man....that's what we're all here for
Old Mar 19, 2009 | 08:30 PM
Degooch's Avatar
okay so i checked the sway bar end links and they all seem snug to me and the spring isnt out of place.
So what the heck is it? Its starting to get worse and worse
Old Mar 19, 2009 | 08:34 PM
Mouse's Avatar
how many miles are on the struts? It could be a strut starting to fail. ..also...check to make sure that the strut tower bolts are not loose... if that checks out and none of the other link components are loose... I would take it in.
Old Mar 19, 2009 | 09:24 PM
Degooch's Avatar
I checked the top of the strut and all 3 bolts were not on very tight so i tightened them and im gonna double check the sway bar and any bolt that i could have missed under the car.
Hopefully tightening those will fix the problem.
And there stock struts on htech springs with about 17,500 miles. Its an 08
Old Mar 19, 2009 | 10:40 PM
Degooch's Avatar
well i guess that did it the noise seems to be gone.
Thanks for your help mouse
Old Mar 25, 2009 | 06:54 PM
QuincyPlatinum224's Avatar
i have the same problem im going to do this today.
tpistoia
Oct 25, 2023 10:06 AM
kb1sxv
Oct 21, 2015 05:00 PM
Andreas24
May 17, 2015 09:05 AM
D_Roke
Mar 31, 2015 05:37 PM
Banana03
Nov 4, 2004 10:21 PM
