AC making water help please !!!
Old May 12, 2009 | 08:42 PM
poonertc's Avatar
Default AC making water help please !!!
OK so i came back from college the other day and i finally got back into the tc !!! but mom told me it was leaking water on the inside when the AC was on and today when i was driving water started to drip in on the passenger side.
I only noticed it when i took a hard left turn. i took the glove box out and i saw a lot of the area was wet mainly to the left of the fan motor.
I have no idea how the AC system works so if anyone has a clue to what this could be that would help a lot !!!
Old May 12, 2009 | 09:23 PM
breimann's Avatar
I'm going on a guess - but it sounds like condensation on the evaporator is not draining properly. I don't know enough about how the tc HVAC is setup to really help more
Are you sure it is water and not anti-freeze/coolant?
Old May 12, 2009 | 09:47 PM
SquallLHeart's Avatar
it's called condensation...
Old May 12, 2009 | 10:18 PM
poonertc's Avatar
yeah i figured it was condensations it looked pretty obvious and it deff water for sure the question is that condensations should be going some were other than inside.
Old May 12, 2009 | 11:13 PM
BZinn1's Avatar
Your drains for the heater core and AC core are plugged.normally it drains out side the car on the ground right next tothe firewall.
Jack the car up and put it on jack stands and you will see the holes that are supposed to drain the water out,most likely leaves or pine needles or dead mouse plugging them up,if I remember there is bolts that can be removed to open it up even.
Old May 13, 2009 | 05:10 AM
poonertc's Avatar
Awesome that sound right to me ill take a look wish i knew before just had the car up on jaks to change the oil
thanks man appreciate it !
Old May 13, 2009 | 02:26 PM
BZinn1's Avatar
no problem.......you can take out the filter from behind the glove box and that will probably be plugged up as well,might even be where the problem is,give that a try first.
Old May 13, 2009 | 08:30 PM
sciontc_mich's Avatar
^^ yup the drain hose is blocked, backing the condensation up and leaking into the interior.
Old May 15, 2009 | 06:55 AM
poonertc's Avatar
OK the problem is fixed ! turns out u dont have to jack the car up if u pull down the carpet on the pasanger side and look to the left under all the AC stuff u can see the drainage tube just pull that out clear it and ur done.
Old May 15, 2009 | 08:41 AM
good deal, so it was clogged?
Old May 15, 2009 | 03:16 PM
BZinn1's Avatar
good to know you can get at it from inside.......gotta go check mine soon as I park next to a tree.
Old May 19, 2009 | 04:32 AM
poonertc's Avatar
yeah it was clogged dont know with what, i just stuck a wire in there and all this water started coming out all i know is its fixed.
xa007xa
Feb 22, 2015 03:05 PM
rrtxdrvr
Jan 24, 2015 03:08 AM
DibujoB
14
Nov 21, 2003 12:26 PM
2fixA
Sep 25, 2003 08:06 PM
