teaser pics FTW! last post for build **update**
Old May 25, 2009 | 11:34 PM
Cinderblock's Avatar
Default teaser pics FTW! last post for build **update**
ok well i finally got my build underway, for now not to many details, just pictures, the piping is stainless, and i am going to heliarch it, just tach'd for now. everything will be heat wrapped wear need be, i've thought all this through so dont bash on me if you think something looks wrong just point it out, the mani isnt to close the firewall, neither is the WG, and the turbo isnt even that close to the battery like i thought it would be. lol
i used the stock manifold, cut it, and flipped it over.
**ok, so i had the turbo on, at 6psi, with an open wastegate, she pulls very hard, harder than my nitrous, but apperently theinjectors wont handle 6psi at WOT with my fuel controller, so i only boosted a few times for a few seconds. otherwise i drove normal and only boosted a lil sometimes. but my old turbo blew the oil seals *now i know its needs a restrictor haha* and when i tore it apart i found out it had a cracked bearing. so it should be back on in 2 weeks when i rebuild it, and after it gets smogged to reregister it in cali.
https://www.scionlife.com/forums/sho...d.php?t=167280
build thread
Old May 26, 2009 | 06:38 PM
Boxer_Rebellion's Avatar
Looks nice to me. Post some numbers when you can
Old May 26, 2009 | 10:57 PM
JSosa's Avatar
good job, makes getting at the turbo VERY easy!
Old May 27, 2009 | 05:11 AM
ya ill keep you guys updated, kinda what i was going for, easy of care and working on the rubo lol. ill have a full build once its finished.
Old Jun 2, 2009 | 07:37 PM
got my oil and water lins routed yesterday, now just waiting to get the mani and dp tig'd
Old Jun 2, 2009 | 07:48 PM
EAmon's Avatar
is it just me or do I see 2 wastegates?
Old Jun 2, 2009 | 07:52 PM
jonathan110987's Avatar
bov and wastegate
Old Jun 2, 2009 | 08:01 PM
rosedaleny806's Avatar
2 wg's
Old Jun 2, 2009 | 09:13 PM
EAmon's Avatar
wow that doesn't look like a BOV to me at all
Old Jun 3, 2009 | 11:13 PM
the Wg is on the manifold, originaly the turbo would have an internal, but becuase the way its clocke di couldnt use the actuator anymore so i welded it shut *and will safety wire it too since i welded on cast* that funny thing on the turbo is the bov. this model has the bov built into it. kinda weird, im still guna block that off and run with the ssqv later tho hahaha :p
Old Jun 3, 2009 | 11:48 PM
EAmon's Avatar
what turbo is that?
Old Jun 4, 2009 | 01:54 AM
clhermitte's Avatar
did you rip that turbo off a volvo? lol
Old Jun 4, 2009 | 11:10 AM
jct's Avatar
jct
hey if it works right...
Old Jun 4, 2009 | 10:33 PM
haha its a td05-12b off of a volvo 240 or 480 i dont remeber. so ya it came off a volvo, and it should work perfect, zpi used the td05-14b for a lil bit and this has a slightly smaller exhuast side. has a tiny bit of shaft play, but ill get it rbuilt later once everything is done and running.
Old Jun 4, 2009 | 11:06 PM
rrimportracer's Avatar
Old Jun 5, 2009 | 12:01 AM
RedneckwithanxB's Avatar
That def is dif... once I go the other way with boost Ill be coming to you for one of those manifolds... That is awesome!
Old Jun 5, 2009 | 12:17 AM
EAmon's Avatar
yeah its funny that hte thing on the turbo looks like a WG when its not huh?
never seen a turbo with a built in BOV before, only WGs
Old Jun 5, 2009 | 05:32 PM
redneck, ill be more than happy to supply one too. and a DP. yeah that turbo threw me for a loop when i first saw the BOV on it haha. no worrys AE. im hoping the welding will be finished today and then i can install it.
Old Jun 14, 2009 | 02:04 AM
autopainter13's Avatar
dont u think the turbo is kinda close to the brake resovior, or is it an optical illusion?
Old Jun 14, 2009 | 04:06 AM
its an optical illusion actually, i ran for a day witht the turbo on *before the old turbo's seals died* and the reservoir never got that hot.
