Headunit Doesn't Turn On
Old Jun 1, 2009 | 04:59 PM
rcf22's Avatar
Default Headunit Doesn't Turn On
I've installed a Pioneer FH-8000BT which has been working great for about 8 months. Today I went to install some cathodes, made a few power connections, and tried a test turn on, but the cathodes did not power up, and neither did the radio head-unit.
I tried tapping the +12v yellow line between the factory radio harness and the Pioneer adapter, and grounding to the dome light wire by the switch panel. I then removed the cathodes and power connections and reverted back to my working set-up before and it still does not power up.
At one point of the cathode installation while tapping the yellow wire for power, the wire accidentally nicked the underside of the headunit housing and caused a small spark. (I had forgotten to disconnect the battery).
So my question is, is there something I should check or fix to help this, or did I accidentally fry my headunit by tampering with this power connection? I sure hope that's not it...
Old Jun 1, 2009 | 05:07 PM
blacktrdtc's Avatar
HaYu Racing
did you check your fuses? probably blew one out. always disconnect your batt when working with wiring in your car.
Old Jun 1, 2009 | 05:13 PM
rcf22's Avatar
d'oh... Of course it's probably a fuse. Where is teh one for the radio located?
Old Jun 1, 2009 | 06:01 PM
rcf22's Avatar
Quick update: stock head unit doesn't power up either. Checked the +12v lines on the OEM harness and there is 12v on the accessory line, but not on the constant on. I checked the 7.5A fuses under the switch panel but didn't see any bad ones. Which one is inline with this constant 12v line?
Old Jun 1, 2009 | 10:48 PM
tcrs2424's Avatar
Sounds like a really dumb response but check ALL of your fuses. Even the 0nes under the hood. Did you check the relays as well? Do you have something to check that the wires are getting power?
Old Jun 1, 2009 | 10:58 PM
LunchBoXB's Avatar
there also may be a fuse in the back of the head unit that you should check for
Old Jun 1, 2009 | 11:07 PM
TokenAsianGuy's Avatar
Yeah mine did the same thing and it turned out to be a 25 cent fuse under the dash. If you crawl under the drivers side and its around the general area of the OBDII port. You'll see it, it had a fuse guide, I opened it up and just pulled one out at a time and then went on until I found one blown. Hope this helps.
Old Jun 1, 2009 | 11:08 PM
SciontC_RS5's Avatar
Pull all your fuses I did something simular with my tC and the Cigerette lighter and it killed the ACC Fuse I believe
Old Jun 1, 2009 | 11:14 PM
rcf22's Avatar
Turns out it was a 20A fuse under the hood labeled RAD1. Not sure what that designation is supposed to be, but I had assumed radiator. Who knows why my radio blew it.
Old Jun 1, 2009 | 11:19 PM
Glad you found it out.
Old Jun 2, 2009 | 03:21 PM
LunchBoXB's Avatar
well... RAD1, and your RADio blew... haha. Glad you figured it out.
Old Jun 29, 2009 | 06:41 PM
malditoxb's Avatar
Thanks guys, had the same issue ... went under the driver dashboard and found a blown fuse... replaced and hello radio!! thanks again
xBSciontist
Jun 18, 2019 03:06 PM
setpol
Feb 17, 2015 11:33 PM
bobc04
Dec 8, 2014 05:01 PM
TJ
Nov 6, 2003 01:16 AM
