How to take off the dash?
Old Jun 20, 2009 | 12:23 AM
myoldtc's Avatar
Default How to take off the dash?
Guys,
I am trying to install an aux cable to my stereo which need me to take the dash off.
I am having a hard time taking the silver trim off , i was able to make it loose but it wont come off.
Could some body throw me some advise on how to take this off ? ?
I saw some thread about doing this but cant find one that really explain it detailly... maybe somebody can point it out to me...
desperately need help and direction
Old Jun 20, 2009 | 12:59 AM
scubatC's Avatar
You should be able to just pull them out, If you are talking about the trim that surrounds your radio then you kinda have to loosen it up then pull up and out on it, the ac vents kinda get stuck sometimes and can take a little wiggle to come out. I cant remember off the top of my head if you need to take off or loosen the trim any around the shifter you can just pull up on that with a little force. Use some judgment on it your not going to break any clips by just pulling up some just dont use so much force that your gonna break or crack the actual trim. Hope this helps some maybe someone else can clarify it a little bit better for you.
Old Jun 20, 2009 | 01:33 AM
captainlaziness's Avatar
Step 1- Pull
Step 2- Ha ha, just kidding! There is no step 2.
Old Jun 20, 2009 | 04:31 PM
myoldtc's Avatar
which direction should I pull ??? TO the side or to the top ?
Old Jun 20, 2009 | 04:34 PM
Start at the top and pull towards the rear or the car. Once the top is loosened, work your way down the waterfall.
Old Jun 20, 2009 | 04:43 PM
rosedaleny806's Avatar
pull waterfall torwards u from the point where the lower waterfall/shifter meets the top waterfall, u have to put ur nails in there and pull
Old Jun 21, 2009 | 02:00 AM
BZinn1's Avatar
to get the waterfall off
put ebake on.....car in neutral......grab gthe silver pieces that are on the console and pull up and back at the saem time.I like to do the passenger side first up a little then the driver side till I get it loose and then pull it up and back,if you have an automatic,the trom piece tends to catch up and that is annoying........
then once you hvae that piece off you can disconnect the lighter plug and shift **** if you have to and take it off.
then phillips screwdriver to remove the two screws at base of waterfall,then lift it out and up just a little as the harness is connected,once it is loose take the top part away from dash a little and remove the harness and you have access to the stereo area.
take your time and once it is out a few times it comes out a lot easier,also make sure the door is closed to the radio so it does not get stuck on the deck during removal.
Old Jun 21, 2009 | 02:52 AM
myoldtc's Avatar
thanks for all response.... I will give it a try..
my last question,, what are all you guys referring as "waterfall" here ?
Old Jun 21, 2009 | 03:09 AM
ZTC's Avatar
ZTC
the silver piece that houses the radio hvac hazards and all that jazz
Old Jun 21, 2009 | 08:32 PM
bsptcftw's Avatar
isn't there a DIY about this somewhere? I'm looking for it myself...need to remove head unit, HVAC, and some other things...
Old Jun 26, 2009 | 01:03 AM
justint's Avatar
Here is the tech article that teaches you how to completely take apart your tC. Everything from seats to your dash.
https://www.scionlife.com/forums/viewtopic.php?t=60981
Old Jun 26, 2009 | 05:51 AM
yellowxhoodie's Avatar
BlingSlade
Oct 19, 2016 12:39 AM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
gqdabien
Sep 17, 2015 09:23 PM
OpTicaL
Sep 16, 2015 10:25 AM
