passenger side mirror turn signal light 2006 xA
Correct me if I'm wrong.
I think all you need to do is remove the black triangle on the inside of the door that houses the tweeter for your radio. (Should pull right off as it has just a plastic plug holding it in 06')There will be a plug that needs to be unpluged and then a few bolts to unscrew and it should pop right off.
Just install the new one, bolt it up and plug in the wire harness.
... that's to remove the entire side mirror.. which was not asked.
take a look at this:
https://www.scionlife.com/forums/tc-tech-diy-1818/mirror-turn-signal-change-24700/
you need to cut that sucker open.
'06 xA, and all year tC have the same mirrors, I just saw the inside of one, and there is soldering required I think.
xBSciontist
Jun 18, 2019 03:06 PM
minter66
Dec 15, 2014 01:45 PM
Opr8r
20
Feb 25, 2004 11:29 PM
