should i change and go colder on my plugs?
Old Jul 14, 2009 | 04:25 PM
streettimetc's Avatar
Default should i change and go colder on my plugs?
my car is a 2006 tc s/c. i'm running 9.5psi pulley,intake,bosh 110 bpv,header full 2.5 exhaust (no cats) and light crank pulley. its on the stock trd tune and on the trd suplied plug and has about 25,000 miles on them. car runs great pulls hard and has no problem like missfire and stalling.just wanted to get input from people with my setup. iv been reading alot about colder plugs. i know that the trd's are 1 step cloder from stock but should i go one more step? and if so witch one's ngk or denzo?
Old Jul 14, 2009 | 06:42 PM
weezyfbayba's Avatar
what was ur dyno numbers?
Old Jul 14, 2009 | 06:47 PM
on stock boost and stock intake 217whp 196wtq
Old Jul 14, 2009 | 06:50 PM
u can do step 1 colder plugs?
Old Jul 14, 2009 | 06:53 PM
you mean 1 step colder then the trd's?
Old Jul 14, 2009 | 06:58 PM
idk there called 1 step colder plugs check out
www.dezod.com
think there like 35$
Old Jul 14, 2009 | 07:24 PM
Jan06xB's Avatar
One way to tell is to look at the plugs and see if they are too hot - blistering or melting deposits on the electrode insulator - if they are a little sooty then you should be ok where they are heat range wize.
Old Jul 14, 2009 | 07:32 PM
jwaggz82's Avatar
i thought the trd kit came w/ one step colder plugs. Most of the time you go s/c or turbo you do one step colder - i havent had my sc on my car in a while and the dealer did the install so i dont even remember.
Old Jul 14, 2009 | 08:29 PM
CarbonXe's Avatar
You're nowhere near needing 2-steps colder than stock. The S/C has never even seen numbers that would need 2-steps colder.
Stick to the TRD plugs.
Old Jul 15, 2009 | 02:46 AM
gompka's Avatar
^ exactly, if it ain't broke don't fix it.
Btw did you install the new shaft? I see you have a header, i would wrap it or get a heat shield if you don't have one of those two already.
Old Jul 15, 2009 | 03:49 AM
gingles's Avatar
you get one step colder plugs with the trd supercharger kit already.....you fine man
my06tc
Jun 25, 2015 12:18 AM
nightfox915
Apr 10, 2015 01:28 AM
mrsocks
Jan 20, 2015 01:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
