Help Engine cutting out at ideal!!!
Old Jul 17, 2009 | 07:15 PM
Iowa_TC1's Avatar
Default Help Engine cutting out at ideal!!!
Hi guys, today I was driving to the store and my engine started cutting out at ideal really bad and running real choppy. I check the plugs coils and injectors already and they all seem to be fine, what else do you guys think I should look for?
Old Jul 17, 2009 | 07:18 PM
LunchBoXB's Avatar
Cutting out at idle*
What do you mean cutting out? Stalling? Sputtering?
Old Jul 17, 2009 | 07:32 PM
ValenciaS's Avatar
are you running tuned or untuned ? what are you AFRS if you have a wideband
Old Jul 17, 2009 | 09:42 PM
Iowa_TC1's Avatar
It tuned, and I have Unichip for EMS, but thats not the problem because I unplug it and used the stock ecu and it still did the same thing.
Old Jul 17, 2009 | 09:58 PM
mospeedtc's Avatar
Does it stay on if you stay on the gas pedal a bit?AFR guage?
The hose on the back attached to the intake manifold popped off mine and it would die immediatly when Idling.
Old Jul 17, 2009 | 10:15 PM
Iowa_TC1's Avatar
Yes If I stay on the gas it will run, but it still runs a little choppy.
Old Jul 17, 2009 | 10:17 PM
mospeedtc's Avatar
I would check all your hoses,also any CEL?
Old Jul 17, 2009 | 10:20 PM
Iowa_TC1's Avatar
No CEL, I will check the hoses thought, because I did have my intake manifold off once. Any other ideas if its not that?
Thanks for the help by the way.
Old Jul 17, 2009 | 10:28 PM
mospeedtc's Avatar
NP Im no expert but I try to give basic advice..... Maybe someone else will chime in with more help but sounds kinda like my problem so Im hoping it just a simple hose GL with it
Old Jul 17, 2009 | 10:30 PM
Iowa_TC1's Avatar
NP Im no expert but I try to give basic advice..... Maybe someone else will chime in with more advice but sounds kinda like my problem so Im hoping it just a simple hose GL with it
Ok I will try that tonight, thanks for your help.
Old Jul 19, 2009 | 12:13 AM
Iowa_TC1's Avatar
Its fix!!!!
Hey a vaccum hose was lose, thanks a lot for the help!
Old Jul 19, 2009 | 05:59 AM
aen's Avatar
aen
generally if a car dies at idle for any reason it's a vac leak.
Old Jul 19, 2009 | 02:38 PM
Warlord's Avatar
^^ yeah, vac or IAC
NonStopTuning
Jun 29, 2015 07:42 PM
viciouzgamer
Feb 18, 2015 03:26 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
DR_xB
Jul 20, 2004 08:31 PM
BlueBox
14
Jan 15, 2004 01:08 PM
