Help Engine cutting out at ideal!!!
Hi guys, today I was driving to the store and my engine started cutting out at ideal really bad and running real choppy. I check the plugs coils and injectors already and they all seem to be fine, what else do you guys think I should look for?
Originally Posted by ValenciaS
are you running tuned or untuned ? what are you AFRS if you have a wideband
Originally Posted by mospeedtc
Does it stay on if you stay on the gas pedal a bit?AFR guage?
The hose on the back attached to the intake manifold popped off mine and it would die immediatly when Idling.
I would check all your hoses,also any CEL?
No CEL, I will check the hoses thought, because I did have my intake manifold off once. Any other ideas if its not that?
Thanks for the help by the way.
NP Im no expert but I try to give basic advice..... Maybe someone else will chime in with more help but sounds kinda like my problem so Im hoping it just a simple hose GL with it
NP Im no expert but I try to give basic advice..... Maybe someone else will chime in with more advice but sounds kinda like my problem so Im hoping it just a simple hose GL with it
Hey a vaccum hose was lose, thanks a lot for the help!
NonStopTuning
Jun 29, 2015 07:42 PM
viciouzgamer
Feb 18, 2015 03:26 PM
