Lots of smoke! Help. Dezod, Ptunning, please chime in
Old Jul 19, 2009 | 04:22 PM
dave2610's Avatar
Default Lots of smoke! Help. Dezod, Ptunning, please chime in
Car is smoking. smells like fuel, oil, and kind of like burning rubber. Don't know why. Compression is good. Had the turbo rebuilt. Oil return is fine. Any ideas on what to do or what it might be?
Old Jul 19, 2009 | 07:00 PM
dave2610's Avatar
Also misfires in cylinders 1 and 2. Checked plugs and coils both were good. My buddy whos a mechanic thinks its the head gasket. Going to do another compression test tomorrow. If it is how much does getting the head gasket replaced cost?
Old Jul 19, 2009 | 07:44 PM
Ace83's Avatar
Ronin Scion
if compression is still good, go for a leak down test as well.. so plugs are good, no signs of detonation? did you check your downpipe or intake pipe for oil or maybe coolant?
Old Jul 19, 2009 | 07:54 PM
crush02342002's Avatar
wow this sucks bro.
how did the comp test come out the first time?
Old Jul 19, 2009 | 08:05 PM
dave2610's Avatar
ace- plugs are good. no signs of oil
crush- they said all cylinders were around 210
Old Jul 19, 2009 | 08:06 PM
gingles's Avatar
time for a build...if not i have a brand new oem headgasket ill send ya
Old Jul 19, 2009 | 08:09 PM
deathbyc4's Avatar
210, is kinda high? may be dependent on motor year. mine's an '05 and at 180psi. higher compression may indicate something is on top of your cylinders and burning also may cause the misfire. just a thought.
Old Jul 19, 2009 | 08:10 PM
dave2610's Avatar
i appreciate that gingles.
Looks like im gonna get the compression test done tonight. So ill let you guys know.
Old Jul 19, 2009 | 09:01 PM
Ptuning_tuner's Avatar
Residual oil in the exhaust system from the previous turbo seal problem?
Old Jul 19, 2009 | 09:35 PM
deathbyc4's Avatar
^ i 2nd that. i had that problem with mine after first rebuild. then i swapped exhaust. problem solved. still doesn't cover the misfiring....hmm...
Old Jul 19, 2009 | 09:40 PM
dave2610's Avatar
i thought the same thing but its just too much smoke. May even be more than before. Also the problem is it may have never be blown. Comp turbo said that when they took it apart the seals were fine. they replaced them anyway.
Old Jul 19, 2009 | 09:44 PM
gingles's Avatar
what color was the smoke again?
Old Jul 19, 2009 | 10:16 PM
dave2610's Avatar
White
Old Jul 19, 2009 | 10:59 PM
Ace83's Avatar
Ronin Scion
how's you coolant level? did you have to add water often?
Old Jul 19, 2009 | 11:06 PM
mine were 180psi except on cyl 3 which was 190psi....could higher compression mean a sticking valve? idk
Old Jul 20, 2009 | 12:28 AM
dave2610's Avatar
Nope coolants good.
Did another compression test
205 205 205 215
Thinking its the piston rings.
Old Jul 20, 2009 | 12:35 AM
SoFloTC's Avatar
my coolant level seems to drop fast and i add water often... but i got no smoke anywhere... why is this? do u think its just the florida heat?
Old Jul 20, 2009 | 05:13 AM
deathbyc4's Avatar
^evaporation through the overflow tank due to under hood temps and FL heat. don't wuote me on that
dave, you could have broke a ring land or two. Def time for motor build.
Old Jul 20, 2009 | 11:53 AM
m6ar2cel6oTC's Avatar
yup might be a piston ring. i got some wiseco pistons for sale for cheap!
Old Jul 20, 2009 | 03:19 PM
dave2610's Avatar
may be in contact with you.
yep
