Lots of smoke! Help. Dezod, Ptunning, please chime in
Car is smoking. smells like fuel, oil, and kind of like burning rubber. Don't know why. Compression is good. Had the turbo rebuilt. Oil return is fine. Any ideas on what to do or what it might be?
Also misfires in cylinders 1 and 2. Checked plugs and coils both were good. My buddy whos a mechanic thinks its the head gasket. Going to do another compression test tomorrow. If it is how much does getting the head gasket replaced cost?
if compression is still good, go for a leak down test as well.. so plugs are good, no signs of detonation? did you check your downpipe or intake pipe for oil or maybe coolant?
210, is kinda high? may be dependent on motor year. mine's an '05 and at 180psi. higher compression may indicate something is on top of your cylinders and burning also may cause the misfire. just a thought.
Originally Posted by Ptuning_tuner
Residual oil in the exhaust system from the previous turbo seal problem?
Originally Posted by Ace83
how's you coolant level? did you have to add water often?
Did another compression test
205 205 205 215
Thinking its the piston rings.
Originally Posted by m6ar2cel6oTC
yup might be a piston ring. i got some wiseco pistons for sale for cheap!
^evaporation through the overflow tank due to under hood temps and FL heat. don't wuote me on that
dave, you could have broke a ring land or two. Def time for motor build.
