underglow wiring question
Old Jul 19, 2009 | 07:11 PM
skinnayyy's Avatar
Team Scionara
Default underglow wiring question
so i don't know if anyone has done this or not, but is there any way that i can wire up an underglow to light up when i want it to by switch, and also light up whenever i unlock and lock my car doors?
my friend gave me the idea for the lighting up when unlocking and locking my doors so i figured i would wire it to my parking lights or something, but then i still want to be able to turn them on and off so they aren't on when i'm driving.
Old Jul 19, 2009 | 08:18 PM
x_Batman_x's Avatar
mhm connect your underglow to to a constant ground and a constant power. Put a switch in line with the wire that is a constant power so you can control it with a switch. Then get out a standard 4 or 5 pin automotive relay. Hook pins 85 and 87 to a constant power source. connect pin 30 to the positive wire of the underglow AFTER the switch, and connect pin 86 to the blue wire under the dash that supplies a ground when the doors are open. Theres a thread around here that shows which wire im talking about. Do a search you should be able to find it.
Old Jul 19, 2009 | 08:28 PM
BZinn1's Avatar
yep that is how it is done exactly,pretty easy to do.
Old Jul 20, 2009 | 04:03 AM
skinnayyy's Avatar
Team Scionara
thanks batman! butttttttttttt i don't really have any idea what that meant. I've wired up things outside of automotive, and that pin 85 and 84 stuff kinda lost me
Old Jul 20, 2009 | 04:58 AM
donnyp05tc's Avatar
Here this diagram should help you. To find that blue wire in the picture, just go to the left of where your fog light switch and blank plates are, and pull that little panel off. That will give you access to the wire you need.
Everything else, you should be able to understand from the diagram.
Old Jul 20, 2009 | 07:54 AM
x_Batman_x's Avatar
nice diagrams man. However i believe that to acheive what he wants the wire coming off of pin 30 should be attached the the underglow's 12v wire on the other side of the switch...
Old Jul 21, 2009 | 12:30 AM
donnyp05tc's Avatar
x Batman x are you sure? If you stick the wire coming off of pin 30 on the OTHER side of the switch, woouldn't their be no power going to the underglow itself if the switch is turned off? Since the underglow powerbox is the Input voltage and your constant 12v is the output voltage,
So then it would only work if the switch was turned on, but then they would stay on regardless if the door was opened or closed?
I'm just trying to double check. Could use a little discussion on this lol.
let me know what you think.
Old Jul 21, 2009 | 12:43 AM
x_Batman_x's Avatar
look at your diagram again. If the switch is open (off position) and you opened the door, power wouldnt be able to reach the underglow control box.
if you put the wire on the other side of the switch then the control box would receive power if you either close the switch or open the door.
Old Jul 21, 2009 | 01:20 AM
donnyp05tc's Avatar
yes, that is correct. Good Point bud. Yeah run the wire from pin 30 to the OTHER side of the switch, just like x Batman X said.
Good thinking man!!
Old Jul 22, 2009 | 04:06 AM
skinnayyy's Avatar
Team Scionara
thanks batman! if i don't have it hooked up the right way by the dream cruise maybe you could help me out during our meet!
Old Jul 22, 2009 | 04:24 AM
x_Batman_x's Avatar
oh shoot I didnt realize you were in MI till just now. haha sweet
wheres the scion meet??
Old Jul 22, 2009 | 05:05 AM
skinnayyy's Avatar
Team Scionara
haha yeah i'm the one thats setting it up. It's on woodward friday august 14th. the day before the dream cruise. I haven't decided where at yet but it'll be at like 13 and woodward probably somewhere around there.. i think you already PMed me your phone number lol
Old Jul 22, 2009 | 05:42 AM
x_Batman_x's Avatar
oh wow look at that i did haha. nice memory ive got.
well aslong as you've got my number, feel free to hit me up if you're having trouble with your underglow
good luck
Old Jul 22, 2009 | 10:18 PM
skinnayyy's Avatar
Team Scionara
well i still gotta buy it... i probably will once i pay off this credit card bill for this month! going to get some for my car and for my bike! ^^
Old Jul 23, 2009 | 01:10 AM
x_Batman_x's Avatar
ah i see.
well if your looking for cheap but quality kits check out: http://tweakedice.com/underglow.html
I get all my lighting for Oznium.com but if i was going to buy underglow I'd get it from tweaked ice because they have much better prices. Plus i used one of their kits in my last car and can vouch that it is decent quality. The only problem i had was that the plastic hangers/brackets broke but if you get some metal components from home depot you would be set.
Old Jul 23, 2009 | 04:48 AM
skinnayyy's Avatar
Team Scionara
ahhh i was probably just going to go with ledglow.com because i can get my car and motorcycle kit from the same place and it's a decent price too ^^
Old Jul 30, 2009 | 08:25 PM
skinnayyy's Avatar
Team Scionara
so i've done everything except the electrical... was just going to make it only go on when i said to no door lock or anything, but then it was 11 pm and i had to do some homework so i stopped.
everything else... putting the wire through the firewall and all that can wait for now.
But quick question, the "switch" is built into the power box for the underglow, so will that make a difference?
Old Sep 13, 2009 | 05:15 PM
skinnayyy's Avatar
Team Scionara
well i know this is kind of a necro post on my own thread, but i just wanted to say thank you for those that helped. i finally finished it all up and it works exactly how i want it to!!
eric
edit. i take it back, i did something wrong, and still only works the way i had it before, and i think i blew the fuse in it or something because it doesn't work at all right now i turned on my car and it made a buzzing noise when i turned it on and i have no idea what it was or where it came from ><
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
vpkb
12
Oct 8, 2003 04:17 AM
