unsure about my tire
Old Jul 25, 2009 | 01:43 PM
ShawnBenton's Avatar
Default unsure about my tire
ok so i have neo nittogen tires and the other week i got a nail in one and had it plugged. well today i was shining my tires and realized that now that tire is on inside out.. meaning all of the other tires say outside on the sidewall and this one now says inside. is this a problem? i do not have much knowledge with tires but i mean its kinda obvious that it isnt supposed to be like that. does anyone know if this is bad and needs to be fixed ASAP or is it something i just need to have fixed when i get around to it?
Old Jul 25, 2009 | 03:41 PM
burstaneurysm's Avatar
You should get it fixed. Those tires are directional, meaning the tread was designed to only go one way. One of your tires is technically going backwards.
Why was the tire removed for plugging? If they did that the other week, take it back there and make them fix it. Otherwise, just hit up a wheel shop and pay the 10 bucks to get it flipped.
Old Jul 25, 2009 | 04:13 PM
Jan06xB's Avatar
It is more about cornering since the tires rotate in different directions on opposite sides of the car. Cornering puts different stress on the inner and outer tread - the tire has a non-symetrical tread pattern right?
Old Aug 8, 2009 | 03:57 AM
Sciond's Avatar
get it fixed ASAP
Old Aug 8, 2009 | 04:29 AM
draxcaliber's Avatar
yeah, if you have directional tires on backwards, it can make things really interesting when you drive in the rain...
Old Aug 12, 2009 | 08:53 AM
daneisthegreatest's Avatar
and the tire wear is probably gonna be a lot worse on that tire if you dont get it fixed soon...def take it back to the shop, they should have caught that in the beginning...
i also want to know why they pulled the tire off the rim to plug it, ive never had to even jack up my car or take the rim off the car to plug it.
Old Jan 11, 2010 | 05:49 AM
whathafeh's Avatar
I'ts usually better to patch the tire from the inside. The technician must have mounted it on backwards. The shop should just apologise for screwing and flip it over.
Old Jan 11, 2010 | 05:52 AM
whathafeh's Avatar
Neo Gen is an asymetrical tire and would probably just handle poorly mounted inside out
Old Jan 28, 2010 | 06:31 AM
bB2NER's Avatar
Music City Scions
Not quite, tires with arrows on the side are directional. Ones that say inside/outside can rotate in either direction as long as the outside is outside. It can still go any place on the vehicle. I just learned this with my new Falken 912s.
skruff
May 6, 2015 08:32 PM
xb4lf
Apr 4, 2015 07:15 PM
oxxomxxo
Feb 19, 2015 01:28 PM
Scionxa180
Scion xA Aero & Exterior
Jan 8, 2015 08:33 PM
kleecker
Dec 31, 2014 09:42 AM
