every1 who has there motor built
Old Aug 1, 2009 | 04:25 AM
garynkim's Avatar
Default every1 who has there motor built
sup every1, just want to make sure i get this right if i put rods and piston in without taking the balance shaft out.. i dont need to balance my engine right? thanks
Old Aug 1, 2009 | 05:14 AM
BlackKnight's Avatar
Music City Scions
Wrong, if you modify the OEM setup i.e. changing pistons and rods it changes the balance. You should delete the counterbalance shafts and rebalance the rotating assembly.
Old Aug 1, 2009 | 06:56 AM
SoFloTC's Avatar
delete ur balance shaft or it will cause problems when u start entering high power
Old Aug 1, 2009 | 10:28 AM
m6ar2cel6oTC's Avatar
^^^^^X2!
Old Aug 1, 2009 | 03:30 PM
gingles's Avatar
the only thing i really had balanced was my crank.....i had them match the rods and pistons weight wise as well. If i could go back id have them rebalance EVERYTHING
Old Aug 1, 2009 | 08:32 PM
garynkim's Avatar
got cha.. if you remove the balance shaft shouldnt you balance the crank pulley and flywheel to? and also the engine becomes a external balance engine after right?
Old Aug 3, 2009 | 01:46 AM
Windu's Avatar
When a rotating assy is dynamically balanced, the rods and pistons are all matched balanced, then a bobweight is used. (piston+rod+rings+rod bearings+wrist pin+locks=bobweight) A bobweight fixture set to the new bobweight is hung from all the rod journals. The crank is then spun and internally balanced with the new bobweights. Then you add the pulley, Flywheel, and pressure plate one at a time bringing them to a zero balance as to not affect the internal balance of the rotating assy.
krazylowgsx
Dec 18, 2016 04:13 AM
hondajt
Dec 14, 2015 12:54 PM
prescottn
Oct 8, 2015 05:31 PM
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
