every1 who has there motor built
sup every1, just want to make sure i get this right if i put rods and piston in without taking the balance shaft out.. i dont need to balance my engine right? thanks
got cha.. if you remove the balance shaft shouldnt you balance the crank pulley and flywheel to? and also the engine becomes a external balance engine after right?
When a rotating assy is dynamically balanced, the rods and pistons are all matched balanced, then a bobweight is used. (piston+rod+rings+rod bearings+wrist pin+locks=bobweight) A bobweight fixture set to the new bobweight is hung from all the rod journals. The crank is then spun and internally balanced with the new bobweights. Then you add the pulley, Flywheel, and pressure plate one at a time bringing them to a zero balance as to not affect the internal balance of the rotating assy.
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
