Xa 6sp?
Old Aug 7, 2009 | 02:56 AM
johnsong19's Avatar
Default Xa 6sp?
I would love to have a 6sp transmission in my Xa. Does anyone have any ideas?
I was wondering if a celica 6sp conversion would be possible.
Old Aug 7, 2009 | 03:01 AM
draxcaliber's Avatar
search, been discussed many times. apparently you have to knotch the frame to get it to fit. go for it.
Old Aug 7, 2009 | 03:09 AM
RedneckwithanxB's Avatar
Or you can alter your trans case for the celica gear set...
Either way, you gotta cut up some chit
Old Aug 7, 2009 | 12:45 PM
jct's Avatar
jct
you'll be taking your car out of the power band if you put in a 6th spd
do what others have done in the past drop in a echo transmission it bolts right up...
Old Aug 7, 2009 | 03:20 PM
But 4th and 5th are only a hair longer, so the rewards really arent there...
Old Aug 8, 2009 | 08:13 AM
bB384's Avatar
IV ACE
Wow! People really need to learn to use the search button. The Celica 6-speed (C60) will not fit into the xA/xB 5-Speed (C150) case, in order to install the C60 gearset you need to do some machining to your C150 case, a C160 is whats needed. The different gearing is compensated for by the shorter final drive. The gearing ends up working well. Do a search and you will find out how to properly get a 6 speed to work in your xA/xB.
Old Aug 8, 2009 | 08:56 AM
Domo's Avatar
whats the point? Does the xA even make enough horses to go past 80mph? Just stick with your 5spd
Old Aug 8, 2009 | 02:38 PM
jct's Avatar
jct
or if you wanted a lower rpm speed you should of gotten an automatic
Old Aug 8, 2009 | 02:41 PM
getaforknjob's Avatar
Old Aug 8, 2009 | 02:53 PM
johnsong19's Avatar
I tried searching for solutions, with both Google and on the forum. I don't guess I was using the right words.
The C60 gear set w/ the C160 case sounds good. Has anyone done this. I'd like to do some more research if some one could get me directed in the right place.
Old Aug 8, 2009 | 03:25 PM
Domo's Avatar
Dude is it really worth it? Enjoy the xA for what it is..a fun gas saving eco car. Even if you discovered a way to swap a six speed, your going to need money and a reputable shop. Not to mention that swaps are never full proof. There will most likely be a problem in the near future. If you want to make your ride better and more enjoyable..invest in a little boost and call it a day. Plus 5 spd is awesome.
Old Aug 8, 2009 | 10:39 PM
bB384's Avatar
IV ACE
No you don't use anything from the C60 at all. The C160 swap is bullet proof, is proven and worth every damn penny. Find a C160, swap only the bell housing from your stock C150, get Corolla S axle seals and notch your driver side frame rail to accommodate your longer transmission case. Other than swapping the bell housing and noticing the frame rail, it bolts right in.
Old Aug 8, 2009 | 10:47 PM
johnsong19's Avatar
Thanks Kevin,
That's the info I've been looking for.
Old Aug 10, 2009 | 04:51 PM
SkyonXa's Avatar
So exactly what does the C160 come in as OE?
Old Aug 11, 2009 | 05:36 AM
bB384's Avatar
IV ACE
AE111 powered Toyota Levin BZG
Fisqual
Sep 22, 2015 05:51 AM
joshuabowman
Oct 15, 2013 12:23 AM
09csM
Jul 9, 2012 02:19 AM
CRIMSONBB
Regional - Desert & Salt
Mar 9, 2010 08:18 PM
Crippie
41
Sep 18, 2008 02:37 AM
