Both Cig lighters out (the one in the armrest as well) NEED HELP
Old Aug 10, 2009 | 03:56 AM
icemanscion's Avatar
Default Both Cig lighters out (the one in the armrest as well) NEED HELP
Both of my power outlets (cigarette lighter type) are out. I switched the Cigarette lighter Fuse (Which was bad) and still neither work. Is it another fuse for the one in the armrest? Please help.
Old Aug 10, 2009 | 03:57 AM
SquallLHeart's Avatar
yes.. they are run on different fuses.
Old Aug 10, 2009 | 04:03 AM
happen to know which one the other one is?
Old Aug 10, 2009 | 04:12 AM
probably the "AUX".. though i would have to check the owner's manual..
or.. you can check it yourself.
Old Aug 10, 2009 | 04:41 AM
shift_fast's Avatar
This happened to me already for about 6 times. I tried all the research and putting lower fuse (from 15, 10, 7.5 amp). But they only work for few days. If you are lucky, they work for about 2 weeks to three weeks max. So what I did is I replaced the fuse for the cig lighter the same fuse (15 amp low profile). Then for the outlet, instead of 15 amp low profile fuse, I upgrade it to 20 amp low profile fuse. So far the fuses never blew ever. It has been a month so far. You can get these fuses at Autozone.
The fuse location is at the driver side, under the steering. Not literally under the steering, but close to where the hatch you open the hood.
Old Aug 10, 2009 | 04:54 AM
circuits are rated to handle a certain amount of amperage..
overriding that by stupidly placing a higher rated fuse in the circuit than what was meant to be in there..
is frankly not only stupid.. but DANGEROUS.
we're talking about melting stuff and starting fires here.
Old Aug 10, 2009 | 05:04 AM
jct's Avatar
jct
just be glad they aren't using a .22 gauge bullet as a fuse
Old Aug 10, 2009 | 06:34 PM
Default 1/2 working
OK so the cigarette lighter still isnt working, the acc lighter in the armrest is. I switched both fuses with the appropriate fuses. Any suggestions / advice?
SouthernCaliTC
Sep 15, 2015 01:58 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
JonathonK
Aug 26, 2015 08:30 PM
ShawnMcc
Jul 11, 2015 11:07 PM
RPMxB
Jul 22, 2004 11:32 PM
