2008-2010 [ZSP110]
Tapping into the dome light?
Old Aug 17, 2009 | 02:13 AM
xD_GirL4's Avatar
Default Tapping into the dome light?
So I want to replace the four "oh ____" handles in my xD with some LED tubes I ordered, but I wanted to know if anyone has tapped into the dome light for power? And does anyone know what each of the color wires are for? Theres a light pink wire, baby blue wire and a white wire with a black stripe on it. Any help would be greatly appreciated!
Old Aug 17, 2009 | 04:17 AM
CSUnited14's Avatar
theres a write up using the tc dome light for a radra a valtine v1 or soemthing might be of some help if u search for install valentine
Old Aug 17, 2009 | 05:21 AM
AcidDrop's Avatar
^she has a xD which is different than the tC, get a test light if you have one and check out each wire which is the only way you'll be able to figure out which wire is for what.
Old Aug 17, 2009 | 11:04 AM
DeathMachine's Avatar
I think the white/black wire is the ground, the blue is constant power, and the pink is variable power/dimmer...
Old Aug 17, 2009 | 07:48 PM
uskrewed's Avatar
This, sort of. The pink wire goes to the ECU and is the "door open ground" when you put the selector to turn on when a door opens. Also, I just wanted to specify, it is a ground wire.
Old Aug 17, 2009 | 10:38 PM
mcbrew's Avatar
Yeah... and blue is constant 12v+ as DeathMachine mentioned.
Old Aug 19, 2009 | 04:46 AM
xD_GirL4's Avatar
Okay so I think I got it.... blue would be my power and pink would be my ground which will also let my lights dim when the door opens/closes. Correct?
Old Aug 19, 2009 | 07:45 AM
uskrewed's Avatar
100% correct.
wonderworm
Nov 19, 2023 01:44 AM
horsefeathers
Sep 17, 2023 11:12 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
XB06
May 30, 2015 02:42 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
