Need help!!! A/C problem
Old Aug 28, 2009 | 03:28 PM
metalranger33's Avatar
Angry Need help!!! A/C problem
So i just got my tc back from my brother and he said on his way down from college station to weslaco tx the ac would blow cold air then stop blowing cold air, and it would that back and forth....now it isnt blowing cold air at all...anyone know????
Old Aug 28, 2009 | 11:45 PM
sw09's Avatar
was the air cold or cool before when it was working?
get a set of vacuum gauges and hook it up, see how much pressure is on the high side and low side of the system
Old Aug 29, 2009 | 12:00 AM
divisii's Avatar
hopefully, you just need a recharge of the freon; that's what's worked for me in the past.
Old Aug 29, 2009 | 12:12 AM
sw09's Avatar
^^yea but if he needs a recharge chances are there is a leak in the system b/c refrigerant leaks minimally through time. and in 5 years it shouldnt leak out to the point that the compressor isnt turning on and the a/c isnt recirculating (thats if he has a 05 tc)
if u bring it to a shop get them to recharge the system and put dye in it. this way they can find the source of the leak with a UV light or leak detector. (that is if the lack of refrigerant is the problem)
Old Aug 30, 2009 | 04:44 AM
AtC's Avatar
AtC
yeah, the valley is usually pretty hot. . .it usually takes my a/c a while to start blowing "cool" air
Old Aug 30, 2009 | 05:06 AM
rangerryda's Avatar
The leak check is easy to do yourself with the kits they sell at auto parts stores. If you are familiar with pressurized systems then it shouldn't be hard to detect where and if there is a leak. Putting in more R134a will temporarily resolve the issue so you won't sweat your ***** off in the meantime.
Old May 6, 2010 | 02:41 PM
ricecooker's Avatar
metal ranger I have the same problem! intermittent A/C, did you ever find a solution?
Rhymenoceros
Scion xD Drivetrain & Power
Jul 2, 2016 10:12 PM
ShawnMcc
Jul 11, 2015 11:07 PM
Opr8r
25
Jan 13, 2004 07:42 PM
a330300
Nov 6, 2003 11:47 PM
Opr8r
Nov 3, 2003 03:34 PM
