HID flickerin wtf!!!
Old Sep 9, 2009 | 03:35 PM
chulopati's Avatar
Default HID flickerin wtf!!!
ok want to thank evryone for there time to help me out wit this here we go
i put in fog lights some time ago and put in H I Ds. i realised the other day that the pasengers side light when turned on will flicker then turn off while the other one remains on no problem. I'll turn it off n turn it back on same result.
should i buy a new light or is it the wiring????
Old Sep 9, 2009 | 04:01 PM
RedneckwithanxB's Avatar
check your wiring, could be as simple as a loose connection somewhere, but it could also be a ballast issue
Old Sep 9, 2009 | 06:23 PM
CSOCSO's Avatar
what do you plug in to the factory harness? is it a plastic connector or just pins what you have to push in to the factory harness?
if pins then pull it out.. try to bend it and twist the pin just a little bit so it will grab tight inside.
if its a plastic connector then check the cables for corrosion.
do you have fender liner? ( that plastic thing goes around the wheel so the water cant get inside the engine bay)
Old Sep 12, 2009 | 12:12 AM
DeRuX's Avatar
Some times the ballast do go bad.
Old Sep 12, 2009 | 02:08 AM
Murphys_Law's Avatar
check wiring, esp ground(?) and connectors, is it one or both?
Old Sep 15, 2009 | 07:50 AM
scion_tuner's Avatar
Scion Kreationz
The kit that you are running, is it a MobileHID kit? I had the same problem with the flickering and it turned out to be the ballast. To check your ballast just turn on your lights, pop the hood up and check to see if you hear any ticking, clicking, or spark sounds inside the ballast. If you do, then it is the ballast. Hope that helps,
Old Sep 16, 2009 | 02:46 AM
island_box59's Avatar
From what my local auto supple store said, you'd have to wire them seperately with relays so that when you turn on your parking lights it will give the ballasts a "heads up" and throw some power to them before you usually turn the **** to on your headlights. I had the same problem myself and bought three freakn kits before they told me this, bumheads! Now they come on both at the same time and no flicker.
yupinmytC
22
Jul 27, 2024 07:08 PM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
