Scion xD ICE & Interior In-car entertainment and electronics...
Replacing maplights, I got a problem. Need help asap
Old Oct 5, 2009 | 09:50 PM
The5ickne55's Avatar
Default Replacing maplights, I got a problem. Need help asap
I figured out you had to turn the holder for the 194 bulb. Well I turn the one, and yanked out the bulb. Problem is now the holder for the bulb went up inside the assembly.... Aka I can't get to it. Does it come out or anything? And how do you put in the bulb ? I need help asap
Old Oct 5, 2009 | 10:05 PM
TRDxD's Avatar
pics speak louder than words; its a little hard to understand what you mean?
Old Oct 5, 2009 | 10:14 PM
TRDxD's Avatar
also, if i remember correctly, the whole assembly for the map lights (front two lights) comes out. you pull that out of the headliner, and the bulbs should come out with ease.
Old Oct 5, 2009 | 10:33 PM
Aphex13's Avatar
Yea, the whole thing should come down. I did the same thing to mine. lol
To change the bulbs, all you have to do is to pull them out. No twisting is needed.
Old Oct 5, 2009 | 10:34 PM
Luc1f3r's Avatar
trdxd is right, just yank the whole assembly down to get the clip out. and no, you did not need to twist prior to pulling. just yanking on the bulb would have gotten it out also.
edit: repost.
Sweet I got it thanks all... now to bend the metal for the trunk light X_X
Old Oct 6, 2009 | 12:55 AM
TRDxD's Avatar
whoa whoa whoa
lol...not again
pop off the square pieces on the interior of the trunk, twist the light assembly and pull out. pull out the bulbs, replace, and repeat for the second side. I scratched the hell out of my hands, but trust....no bending needed...
Old Oct 6, 2009 | 01:35 AM
JJGeneral1's Avatar
Originally Posted by TRDxD
whoa whoa whoa
lol...not again
i think he means the cargo light....
Old Oct 6, 2009 | 03:05 AM
TRDxD's Avatar
i would hope so..
Old Oct 6, 2009 | 03:40 PM
xDTool's Avatar
whoa whoa whoa
lol...not again
He probably got the wrong size festoon bulb (the trunk/cargo light is a bigger festoon), easy fix is just to bend in the metal tab a little bit to fit the new bulb.
Old Oct 6, 2009 | 11:02 PM
TRDxD's Avatar
I was under the impression that he meant the trunk lights, i.e., license plate lights. the ones actually in the hatch. but anyway, the cargo light is the same size as the overhead light (door light) so there shouldn't really be any need to bend tabs? i only know the size of the bulb...to be honest, i couldnt pop off the cargo light cover, and i was on the verge of snapping it when i tried to pry it out, so i stopped
Old Oct 7, 2009 | 12:15 AM
Sefi's Avatar
Maybe on the 08's the cargo is the same as the dome but my 09' and some other people's I've read on here the cargo is bigger than the dome. So it is neccessary to bend the metal clip that holds the cargo light in place if you get the same size festoon as the dome light! Needlenosed pliers and a bit of finagling will make it work just fine!
Old Oct 7, 2009 | 01:18 AM
TRDxD's Avatar
ah guess i must have been mistaken then. its chillin
Old Oct 7, 2009 | 02:10 AM
mcbrew's Avatar
Ummm... I almost hate to ask this... but why not get the correct festoon bulb for the cargo area instead of bending it to fit the wrong bulb?
Old Oct 7, 2009 | 02:57 AM
JJGeneral1's Avatar
cause they don't got LED in that size....
didn't need needle nose... just used the trusty old finger-oo's
Old Oct 7, 2009 | 02:58 AM
TRDxD's Avatar
hehehehehehehhee.
forril though. bulbs are cheap as hell, why not just pay for the proper size
edit:
nvm just saw post above...i guess it makes sense...
Old Oct 8, 2009 | 03:24 PM
mcbrew's Avatar
Yeah... makes sense if you want to go with LEDs.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
my06tc
Jun 25, 2015 12:18 AM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
EvalEvan66
Jan 27, 2015 02:26 AM
