AEM TRUboost
Old Oct 28, 2009 | 11:56 PM
Hix's Avatar
Hix
Default AEM TRUboost
So I got my TRUboost programmed finally... When I crank it up to 10 PSI (17% duty cycle) I can get 10 PSI pretty much as soon as I stomp the pedal but it makes a wooshing and fluctuates quite a bit. I will range from 7.8ish to 10.01 PSI and the car responds in kind with the sound. Really feels weird. Is it possibly a bad solenoid or a bad wastegate? Or is it a fail AEM design?
Search fu in here and google failed me.
Old Oct 29, 2009 | 12:16 AM
cburglb34's Avatar
is ur tc a 07-09? if so u need to tap the boost source from the brake booster because for some reason taping the evap will give u fluctuations in readings
Old Oct 29, 2009 | 12:21 AM
crush02342002's Avatar
his vac source is comeing from the brake booster...i made sure of it. I just havnt really played with the tru boost and dont know much about it.
Old Oct 29, 2009 | 12:22 AM
kyle talk to Ace83... he has the true boost.
Old Oct 29, 2009 | 12:29 AM
cburglb34's Avatar
well he said the car make a whooshing sound and the car reacts when the sound comes my guess is....his wastegate is opening and closing as it pleases, open up the wastegate and inspect everything is tight...
Old Oct 29, 2009 | 12:32 AM
Hix's Avatar
Hix
Wastegate internals look good but they are pretty worn. I might upgrade to a Tial and a 10psi spring, can't afford it right now though. I have a problem on the straight spring set up too, I get 6PSI from the second I touch the pedal down but don't get past it until peak RPM.
Old Oct 29, 2009 | 12:33 AM
kyle next time ill sit down and work with it....i didnt want to before cause i have never played with it and i was more concerned about tuning than anything els. btw i got some goodies to put on your ride (just some ish thats been laying around). marcial wants to do the clutch at your house, is that cool with you?
Old Oct 29, 2009 | 12:35 AM
Hix's Avatar
Hix
Yea bring it. I will try to do my motor mounts while you are there too. Just need your guidance I should be able to put them in myself.
Old Oct 29, 2009 | 12:46 AM
yeah thats cool...i pm'd ace about it, i know there are more on here that have it but ace just pops in my head.
Old Oct 29, 2009 | 12:53 AM
i didnt mean anything by it, i just have personal exp with his car.
Old Oct 29, 2009 | 12:54 AM
cburglb34's Avatar
^^gotcha.....ask scionfred i know he has a xb2 and runs a aem tru boost...hes a nice lil techy dude
Old Oct 29, 2009 | 01:57 AM
Ace83's Avatar
Ronin Scion
ok i just read the details quick.. i will read it again lol.. some questions, how much did you set your wastegate crack/spring pressure? is it like a sound like opening and closing of wastegate? i noticed that on the aem truboost at certain setting.. what size wastegate? and spring?
Old Oct 29, 2009 | 02:00 AM
38mm turbonetics (non adjustable)
Old Oct 29, 2009 | 02:09 AM
Hix's Avatar
Hix
^^ what he said + 8.7psi
The old style Evolution WG. The solenoid knocks like crazy and I hear a woosh woosh woosh woosh kinda like someone is blowing and moving their tounge (hard to explain). It is my PSI goes to max boost at like 2k RPM and then fluxuates like mad.
Old Oct 29, 2009 | 02:11 AM
cburglb34's Avatar
max boost at 2k? wtf turbo do u have
Old Oct 29, 2009 | 02:12 AM
Ace83's Avatar
Ronin Scion
to be honest truboost is not the best boost controller there is, it doesnt give a steady all flat boost control but you can get it close.. i would only rate it 7/10. that issue could be several things, if you want to rule out that its the controller.. try boosting with it and just boost through atmosphere. It could be the wastegate spring pressure setting or your duty cycle setting in relation to the stiffness of your spring.. the wastegate size and time of dump tube could also affect that..
Old Oct 29, 2009 | 02:16 AM
btw kyle can you send me marcial's finished map and yours...want to keep em on file (you never know when you might need em again). oh and your last log and marcials
I think its labeled marcialsclutchkillertune
Old Oct 29, 2009 | 02:31 AM
Ace83's Avatar
Ronin Scion
Ok try this,
1. boost without it... does boost stay consistent? stays at around your spring rate are 8.7 to 9.5ish psi? If its not consistent that could be your problem right there or if its something minor it could add to the boost controller issue
2. Try to check your wastegate lines if theyre all good.
3. try playing with the spring rate/wg crack setting, to high would cause boost to be bouncing and too low could slow down boost build up. Try putting up the setting to 20% too.
4. Switching your vacuum source of your top and bottom wg lines might be something you want to try..
On mine on very low setting of duty cycle, it kinda makes the wastegate open and close while boosting and it makes that woosh woosh sound, boost fluctation is seen on data log but its not too bad on mine though. I think when that happens is that spring and the pressure press against it is fighting, you can make better by playing with the settings.. Or could happen if boost pressure on the lines are inconsistent or pulsating
Old Oct 29, 2009 | 04:45 AM
Hix's Avatar
Hix
Originally Posted by Ace83
Ok try this,
1) No it sits around 6.5psi and only hits 8ish before a shift.
2) They look good, no leaks that I can see.
3) I am gonna try that too I have it set at 8.6 right now, 20% would give me like 11 something psi.
4) I followed the picture but it's not hard to swap em'.
And whoever it was who asked what size Turbo it is it's a very very very tiny Turbonetics turbo. t3/t04B 50 or something like that
Old Oct 29, 2009 | 04:48 AM
dude promis me you wont boost 20psi again!!!!!...lmao
