HELP!!! nasty CELs keep coming and going away...
Old Dec 6, 2009 | 02:30 AM
16G-Scion's Avatar
Thumbs down HELP!!! nasty CELs keep coming and going away...
for the past 2 days...i've been getting the following codes:
P0012 CAMSHAFT ACTUATOR A, TIMING RETARD
P0335 CRANK POSITION SENSOR MALFUNCTION
P0138 02 CIRCUIT HIGH VOLTAGE (I already know that one...faulty wires)
I'm running a custom t3/t4 turbo kit with 550cc injectors...and an AEM FIC
Any ideas would be great guys!!!
Old Dec 6, 2009 | 02:32 AM
cburglb34's Avatar
u need to do the resistor mod
Old Dec 6, 2009 | 03:03 AM
16G-Scion's Avatar
Forgot to mention that my boomslang has the resistor mod...
Old Dec 6, 2009 | 03:04 AM
cburglb34's Avatar
kk remove the resistors then cuz scionfred got those codes with the risistors on it
Old Dec 6, 2009 | 03:11 AM
16G-Scion's Avatar
So my boomslang probably never needed them in the first place lol!
It's actually only 2 months old...so maybe Dezod updated the design or something...
I'll try that then...
Old Dec 6, 2009 | 03:15 AM
highvoltage1's Avatar
Yea but doesnt the TC need the resistors? I thought it was the XB2 tht didnt need them only?
Old Dec 6, 2009 | 03:18 AM
16G-Scion's Avatar
See that's what I thought too?
Old Dec 6, 2009 | 03:47 AM
cburglb34's Avatar
not every tc needs em
Old Dec 6, 2009 | 03:49 AM
Oh ok! Is there a model year that does and doesnt or is it hit or miss?
Old Dec 6, 2009 | 04:49 AM
cburglb34's Avatar
generally a hit or miss, but if u have a 07 or higher id suggest u do it just incase
Old Dec 6, 2009 | 04:56 AM
Blue_TC_Man's Avatar
yeah my 06 doesnt need them
Old Dec 6, 2009 | 06:23 AM
weezyfbayba's Avatar
could be the tune also?
Old Dec 6, 2009 | 08:14 AM
ScionFred's Avatar
Need more info! How long has the FIC been installed? 2 days or longer? Are these new codes or did they coincide with the FIC install or some other change?
If the codes originated with the FIC installation, you should probably try removing the resistors. If the car ran fine with the FIC and resistors until 2 days ago, you should check to see if the tiny 1/8W Boomslang resistors are blown. If some other change caused these codes to appear, what was it?
According to AEM, the crk/cam resistors are typically not needed on most Scions/Toyotas. I can't vouch for the accuracy of their recommendation but in my case (08 XB) the resistors caused the exact same misfire problems and codes that the resistor mod is intended to fix.
Old Dec 6, 2009 | 10:11 AM
16G-Scion's Avatar
The car was running fine since the FIC was installed 2 months ago...these codes started to appear together 2 days ago...btw...omit the 02 sensor code...i'll have to check the resistors on harness....Is it best to just remove them period??
But what was weird when my car was on the dyno...it still sputtered on mid to high RPM ranges with the resistor mod intact yet with some tuning they removed it. Now these codes showed up yet the performance of my car has not been affected whatsoever(the CELs are just very annoying because it comes and then it clears itself after a few hours)
What about resetting the ECU? Could that be an option? It actually has not been done yet...
Old Dec 6, 2009 | 10:17 AM
16G-Scion's Avatar
My TC is an 2007
Old Dec 6, 2009 | 10:38 AM
crush02342002's Avatar
its not year dependant...so far iv had to install the resistors on an 06 and an 07 so i dont think it matters on year.
I might try them without and see where that gets ya.
if you have an ohm meter id check em out with that first.
Old Dec 6, 2009 | 02:19 PM
3min3m2's Avatar
Multimeter FTW definetly.
Old Dec 6, 2009 | 02:24 PM
rangerryda's Avatar
07 here, no resistor, no code
Old Dec 6, 2009 | 02:45 PM
16G-Scion's Avatar
Well slap me around and call me a NOOB but....
How in the world do you use a ohm meter?
