HELP!!! nasty CELs keep coming and going away...
Well...I spoke with Dezod yesterday and I was told that all the boomslangs manufactured about 1 year ago or so already have the resistors embedded into the harnesses so my radio shack 2.2k resistors are screwing up the signals. He told me to remove them from the harness completely and I should be in a good shape.
Do you have pics of ur setup?
Are you referring to the embedded crank resistor in the harness that Dezod put in?
yes hes referring to the one dezod installed
look just remove the resistors that the shop added, keep dezods embedded rsistors, and if u still have problems remove the dezod embedded CRANK resistor not cam just crank
IMHO, whether you need crk/cam resistors or not may well depend on your crk and cam sensor signal voltages, your FIC's sensitivity and your line noise on the crk/cam signals. I believe there is enough variance between individual sensors/FICs/line noise to explain why some applications need the resistors while others can't use them.
Hey Elevation, I don't know if you meant my setup or 16G's but mine is here: https://www.scionlife.com/forums/sho...d.php?t=176230
my06tc
Jun 25, 2015 12:18 AM
randode
10
Dec 11, 2003 06:05 PM
