driver door is about to fall off!!! lol help!
Old Dec 10, 2009 | 08:36 PM
tCjosh's Avatar
Default driver door is about to fall off!!! lol help!
i wanted to know if i could replace this piece on the inside of the door that basically holds the door in place, i think??? its kinda hard to explain so ill show a pic of it:
as you can see, the bottom bolt/nut broke off, i dont know when or how, and everytime i open the door that whole piece gets pushed into the door from the broken bolt and snaps as if the top bolt is getting ready to go too... is there a replacement part i can buy? what is this piece called?
thanks for any help!
Old Dec 10, 2009 | 09:10 PM
SquallLHeart's Avatar
i don't see a picture..
Old Dec 10, 2009 | 09:11 PM
nodsetse's Avatar
I don't see a pic either, and can't tell what it is from your description.
Old Dec 10, 2009 | 09:44 PM
scionic128's Avatar
no pic from me
Old Dec 10, 2009 | 10:48 PM
BZinn1's Avatar
gonna need a picture........door is held on with several bolts,at least two on top hinge and two on bottom hinge........gonna need pictures
Old Dec 10, 2009 | 11:20 PM
tCjosh's Avatar
ok i guess i put the pic wrong... lets see if this works:
Old Dec 11, 2009 | 12:41 AM
Perroski's Avatar
that doesnt hold the door in place, that right there is what prevents the door to not go all the way out when you open it. what you need to do is go to your dealer or to a junker and find the same part and just replace the one in your car. its not that hard, just take off your door panel and take it out trough there. hope this helps
Old Dec 11, 2009 | 12:59 AM
tCjosh's Avatar
yea i figured that thats what i need to do... im just gonna go to the junk yard and get one off a tc that i've seen there instead of going to the dealer and pay probably triple of what the junk yard will charge! any chance of knowing what this part is called????
Old Dec 11, 2009 | 02:11 AM
Aphex13's Avatar
What color is your car? Looks orange in the pic.
Old Dec 11, 2009 | 05:10 AM
BZinn1's Avatar
yeah hit up junk yard,should be able to get that piece for under $20 f you pul it yourself probably less,cannot remember what it is called for some reason i am drawing a blank.
Old Dec 11, 2009 | 05:14 AM
DJ08tC's Avatar
thats because it is, it is custom
Old Dec 11, 2009 | 06:07 PM
tCjosh's Avatar
thats cause it is orange... kind of like the le mans sunset color of the 350z but its called molten bronze...
only pic i really like.. need to take more, hopefully tomorrow
Old Dec 11, 2009 | 07:10 PM
sciontc_mich's Avatar
It's called a door check. And there is an updated part because it could bend easily before they fixed it. 05-07 used the old part. Here is the tsb (tech service bulletin)
http://tijil.org/Scion_TSBs/bo02906.pdf
Old Dec 11, 2009 | 07:25 PM
tCjosh's Avatar
thanks! ill go to the dealer and see what they say...
Old Dec 11, 2009 | 09:29 PM
nodsetse's Avatar
Ya, thanks for that!
I wasn't aware of the issue, sad to see, but at least they acknowledged it via tsb.
Old Dec 12, 2009 | 11:18 AM
^^ yeah it looks like if you keep the nuts on the door check snug then usually it won't bend on its own. But unfortunately the problem happens when those nuts move, shut the door.. pow! there goes the door check glad i could bring it to your attention (Everyone)
Old Dec 15, 2009 | 01:35 AM
n01z3's Avatar
I have the same problem... I wonder how much cost each piece...
Thankx for the TSB
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
DaBlackBox
134
Apr 10, 2022 02:04 PM
