plastic nipple fell in 5MT when doing fluid change.
Old Dec 19, 2009 | 09:22 PM
MarkyD's Avatar
Default plastic nipple fell in 5MT when doing fluid change.
This sucks.
I was using a pump that attaches to the amsoil bottle. On the other end is a plastic nipple you stick in the fill hole, and you pump the trans fluid right in.
Well, it fell in. All the way in. I re-drained it (bye bye $30 worth of Amsoil) hoping it would come out the other end, but not even close. It's stuck in the valley of the transmission casing below the fill plug.
What I've tried to get it out:
-coat hangar
-long pick-hook type thing with a screwdriver handle
-shop-vac with a tube duct taped to it, trying to suck it out.
It won't budge. I can't tell if I'm just not reaching it, because there is no way to get light in there and an object for fishing at the same time. I'm almost to the point of taking this f***ing thing apart. I've been at it 5 hours in some messed up yoga poses trying to see in the hole and fish this piece of sh!! out. GDI SOMEONE PLEASE TELL ME I AM NOT OUT OF OPTIONS.
What happens if I just...leave it in there?
Old Dec 19, 2009 | 10:33 PM
silverstreaktc's Avatar
throw a match down there and burn it out
Old Dec 19, 2009 | 11:34 PM
jct's Avatar
jct
http://www.plumbingdirect.com/ridgid...ategoryid=1027
some thing like that but you can get 'em for much much much much cheaper then that if you can still see the nipple piece that you dropped in...
Old Dec 19, 2009 | 11:54 PM
DTC08's Avatar
not sire what youre trying to say but once had a piece of metal fall into the trans of my old car, i used a magnetic extended stick, but in ur case a stick and piece of gum, try vacuuming it out, or small bursts of air with an air compressor... let us know, GL
Old Dec 20, 2009 | 12:14 PM
MadMike550's Avatar
first off,
you sound very frustrated (rightfully so)
first thing to do is step away from the car to collect yourself...perhaps a dental inspection mirror can help you locate the piece to see what position it is in
you might have to bend your own custom tool out of a hangar
good luck
if you feel your blood start to boil
step away from the car....
Old Dec 21, 2009 | 02:43 AM
MarkyD's Avatar
well, I took the side of the tranny case off. Yeah, it came to that. I was able to see it and dig most of it out, but it was so brittle that it kind of came apart. As was mentioned, I'm going to drive it around for a day or two, then drain/fill again. for now, it seems to be driving OK (5 mile or so test drive just now).
thanks again, everyone.
pro710
Dec 27, 2023 03:34 PM
gqdabien
Oct 8, 2015 05:36 PM
SoccerBoy_AP
Oct 1, 2015 06:28 AM
olyellr
Sep 28, 2015 10:32 PM
user9430961
Sep 24, 2015 01:09 PM
