NA AFR Readings
Old Jan 1, 2010 | 03:34 PM
3min3m2's Avatar
Default NA AFR Readings
*If this needs moved, please do so. I assumed more responses in FI section*
So I have a turbo kit coming soon. To save some hassle, I went ahead and installed my UEGO and boost/vacuum gauges.
Here are my "stock" readings, was curious if anyone else was in this ball park
Idle ~15.3-15.5
Cruise~14.2-15.5(bounces a lot...normal?)
WOT~12.5(works its way to 12.5 near the upper RPMS) but it also seems to "accept" 13 as well. Haven't made a lot of runs yet to see
Also I have noticed under medium accelerations is when the AFR is most stable. cruising that thing is none stop bouncing...
Has anyone else taken data on thier NA tc?
Old Jan 1, 2010 | 04:22 PM
rangerryda's Avatar
I've done MAF and O2 voltage data logs with an F/IC on a bone stock 2009 to help with tuning. The bouncing is relatively normal.
Old Jan 1, 2010 | 05:50 PM
3min3m2's Avatar
I've noticed that car tends to lean towards the lean side, same for your case?
Old Jan 1, 2010 | 05:53 PM
draxcaliber's Avatar
seems about right. that is where my tc was when it was supercharged roughly. but your stock a/f's should be fine since they were tuned by toyota. only way your readings would be off is if the o2 sensor for the a/f gauge was misplaced and getting a bad reading.
Old Jan 1, 2010 | 06:11 PM
3min3m2's Avatar
Yeah I'm sure its not wrong, i just wanted to compare with anyone else who had done it.
I put the Wideband in the Spipe, before the 2nd factory O2. Sound right?
Old Jan 1, 2010 | 06:14 PM
ElevationTC's Avatar
Were your wideband mounted..
Stock header?
Old Jan 2, 2010 | 03:10 PM
rangerryda's Avatar
Before the secondary O2 is just fine. No airflow complications if there isn't a sensor right in front of it.
Old Jan 2, 2010 | 03:40 PM
But if he has a stock header this can and will throw off readings!
Old Jan 2, 2010 | 03:54 PM
3min3m2's Avatar
No I have a megan Header...MY stock one is pretty much shot...
Plus I'm going turbo soon... So this seemed like a logical place, far enough from too high of temps according to AEM?
Old Jan 2, 2010 | 05:07 PM
rangerryda's Avatar
You could be as close as the primary O2 sensor in actuality but for a longer sensor life (negligible) it's recommended to be put farther away. I have mine in the very beginning of the mid pipe because my S-Pipe was going to be changed out soon when I got the bung welded in.
Old Jan 2, 2010 | 07:45 PM
3min3m2's Avatar
I just went with what the AEM instructions said. they call for 36 inches if turbocharged, so i guesstimated, and threw it in where it was easy to get to...
I think it will be fine though...
yhwhdesign
Mar 7, 2015 02:01 AM
DougC
Feb 22, 2015 02:39 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
