NA AFR Readings
*If this needs moved, please do so. I assumed more responses in FI section*
So I have a turbo kit coming soon. To save some hassle, I went ahead and installed my UEGO and boost/vacuum gauges.
Here are my "stock" readings, was curious if anyone else was in this ball park
Idle ~15.3-15.5
Cruise~14.2-15.5(bounces a lot...normal?)
WOT~12.5(works its way to 12.5 near the upper RPMS) but it also seems to "accept" 13 as well. Haven't made a lot of runs yet to see
Also I have noticed under medium accelerations is when the AFR is most stable. cruising that thing is none stop bouncing...
Has anyone else taken data on thier NA tc?
Idle ~15.3-15.5
seems about right. that is where my tc was when it was supercharged roughly. but your stock a/f's should be fine since they were tuned by toyota. only way your readings would be off is if the o2 sensor for the a/f gauge was misplaced and getting a bad reading.
No I have a megan Header...MY stock one is pretty much shot...
Plus I'm going turbo soon... So this seemed like a logical place, far enough from too high of temps according to AEM?
You could be as close as the primary O2 sensor in actuality but for a longer sensor life (negligible) it's recommended to be put farther away. I have mine in the very beginning of the mid pipe because my S-Pipe was going to be changed out soon when I got the bung welded in.
I just went with what the AEM instructions said. they call for 36 inches if turbocharged, so i guesstimated, and threw it in where it was easy to get to...
I think it will be fine though...
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
