Problem with '05 tC's A/C
Old Jan 8, 2010 | 02:04 AM
wOoOzZy's Avatar
Default Problem with '05 tC's A/C
It's been quite a while since I've been on SL but I'm back with an issue on my '05 tC. Wanted to see if this was a problem that has been creeping up on the older tC's or if it's unique.
For the last 2-3 weeks, my A/C has been acting up. I would randomly have to turn it all the way up for the fan to turn on. The inside/outside ventilation worked fine and it would still be cold when it would turn on.
As of about 3-4 days ago, it stopped turning on completely. The inside/outside ventilation still works and the thermostat still works. It's just the fan that won't turn on.
Anybody have any suggestions on how to fix this? Is it something I could do myself or would I have to take it in to a shop? All I can say is thank god that it's winter or else I'd be dieing without A/C.
Old Jan 8, 2010 | 03:41 AM
Kanchi's Avatar
Mine died @ 34K miles, but didn't know it until summer (38k) Defrost still works, but A/C is toast, I know there are a couple more in the area too...sux 'casue the dealership wants like $1700 for R&R + compressor
Old Jan 10, 2010 | 12:38 AM
wOoOzZy's Avatar
Ouch. That's pretty rough man.
So I'm guessing from the lack of posts on this that it's not a common problem with a simple fix and will have to take it in. Not looking forward to this one. =/
Old Jan 10, 2010 | 12:53 AM
dodaddy's Avatar
^^ I just threw away my condensor and sold my AC compressor for $100 bucks lol
Old Jan 10, 2010 | 07:29 AM
sciontc_mich's Avatar
if you're saying that the blower fan isn't working, then that's a relay that controls that blower function. The a/c itself is actually the compressor,condensor, and evaporator, the blower is just the air fan that blows the air out of your vents.
the relay that controls the blower is right next to the blower under the glovebox area. might want to check that.
the other possibility is that the fan controls on the hvac board have died, now I have seen that some tC's pre-07 (07's had a lot of board issues) have died and needed to be replaced. I think that the ledmod guy was selling the boards for $75 which then you'd have to transfer all the buttons and ***** to the new board. It's a better deal since the dealer new wants something like $600 for the board! crazy I know.
But the a/c isn't bad if the blower fan isn't working. Hope that helps ya.
Old Jan 10, 2010 | 11:45 AM
Lil_Deuce_tCoupe's Avatar
Either that, or some of us haven't had to turn it on recently........
Old Mar 13, 2010 | 04:38 PM
wOoOzZy's Avatar
Thanks for the replies. The problem fixed itself. I'm not sure what was causing the problem but it seemed to happen only when it got cold. Ever since the temperatures got out of the 30s/40s it's been fine.
Old Mar 13, 2010 | 04:47 PM
engifineer's Avatar
As far as the 2007 issue with the lighting on the HVAC, I figured that out and posted up a fix for that a long while back. I do it for free along with an led swap on a 2007 and do it for about $10 if someone just wants the fix
I have known of a couple of boards that had issues with the fan control not working. Since I have pretty much mapped most of the circuit on the HVAC unit since 2004 I spent a while troubleshooting one. It seemed to come down to a driver module issue, but replacing the board (you can get a used HVAC for around $50 if you look around) ended up being the best fix.
First step is to see if the blower relay is good. If all that work, you need to start looking at the HVAC module itself.
Old Mar 13, 2010 | 04:48 PM
engifineer's Avatar
As far as only not working in the cold and only not working on AC, then it has to be the HVAC module. If it were the blower control relay it would not blow air on heat either.
Old Jun 30, 2010 | 01:53 AM
guerro's Avatar
My car has developed this same problem. A/C works and gets cold. But sometimes the fan doesn't come on. If I drive down the road a bit, the fan will then come on and work. I am thinking it is a relay.
Rhymenoceros
Scion xD Drivetrain & Power
Jul 2, 2016 10:12 PM
ShawnMcc
Jul 11, 2015 11:07 PM
Opr8r
25
Jan 13, 2004 07:42 PM
a330300
Nov 6, 2003 11:47 PM
Opr8r
Nov 3, 2003 03:34 PM
