What type of oil is best for a Turbo tC?
Old Jan 29, 2010 | 01:10 AM
bigG2148's Avatar
Default What type of oil is best for a Turbo tC?
I'm using Pennzoil synthetic 10-30 question is are most of u Turbo guys running synthetic or regular?, and what is the best oil for Turbo vehicles?
Old Jan 29, 2010 | 01:19 AM
crush02342002's Avatar
there is no right answer but almost all turbo guys use synthetic, me iv used the same oil as you while turbocharged. its not bad, your ok
Old Jan 29, 2010 | 01:44 AM
draxcaliber's Avatar
mobil1 synthetic, 5w30.
Old Jan 29, 2010 | 01:49 AM
t_urbo_C_harged's Avatar
I have been researching, and really I think it is all a matter of what you feel is best. Personally, I will be running mobil1 0w-40 for this winter when I change it in a few weeks then I will be running Rotella T Synthetic 5w40. From my research, I have found that having a higher weight oil will protect better from sheering and heat. So I will run these from now while I am n/a and will continue to when I am boosted. Only downside to running a heavier weight is lower fuel economy and you might loose a tiny bit of power as it is harder for the engine to rotate through it. Research, get on bobistheoilguy.com, and find out what would be best for you .
Old Jan 29, 2010 | 01:56 AM
cburglb34's Avatar
preference and for the record i have used regular oil for breaking a turbo in
Old Jan 29, 2010 | 02:21 AM
tckid631's Avatar
im using 10w30 mobil1 extended performance. Ive used RP also but I dont really see the difference in RP from mobil1
Old Jan 29, 2010 | 02:40 AM
ask any greek, olive oil is the best oil out there, bar none. use it and you will be amazed at the results.
Old Jan 29, 2010 | 02:58 AM
tcturbo07's Avatar
I use mobil 1 synthetic
ScionFred's Avatar
There are lots of opinions on this but I prefer 5w30 for Mid Atlantic winters and 10w30 for summer. I don't like 0w** oils because of the thin base stock nor do I like large viscosity ranges like 5w40 because oils use polymers to acheive multi-viscosity grades. The wider the range, the more polymers and polymers can break down and create sludge. If I ran my car harder I might consider 10w40 or 15w40 in the summer. I run nothing but full synthetic in my car but I run nothing but "non-energy conserving" dino 15w40 in my V-twin motorcycle because of the wet-clutch.
Old Jan 29, 2010 | 03:10 AM
bigG2148's Avatar
okay cool so pretty much every1 is on the same page
Old Jan 29, 2010 | 04:18 AM
gingles's Avatar
i run 10w30 year round in colorado. thicker weight protects the turbo seals
Old Jan 29, 2010 | 01:49 PM
Ace83's Avatar
Ronin Scion
10w40 here on summer, 5w30 winter... tx weather though brands i would use, motul, redline, amsoil and royal purple
Old Jan 29, 2010 | 02:00 PM
cburglb34's Avatar
Eneos oil too ace cant forget the 9 dollar a qt oil...
Old Jan 29, 2010 | 02:18 PM
ElevationTC's Avatar
How about a customer of mine got his oil changed at dealer.. And they used 0w20 in his ptuning turbo tc !
Old Jan 29, 2010 | 02:28 PM
cburglb34's Avatar
LOL gotta love the new toyota standard mike
Old Jan 29, 2010 | 02:31 PM
iv used 5w20 penz synthetic for a year turbocharged
Old Jan 29, 2010 | 02:32 PM
cburglb34's Avatar
yea i did this on my first two kits but those only last 2 months tops
Old Jan 29, 2010 | 05:19 PM
brett561tc's Avatar
<----- royal purple 5w30.
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
kendrick77
Apr 10, 2015 05:06 PM
psturm
Feb 18, 2015 11:12 PM
eric_m
79
Mar 17, 2013 12:21 AM
