What type of oil is best for a Turbo tC?
I'm using Pennzoil synthetic 10-30 question is are most of u Turbo guys running synthetic or regular?, and what is the best oil for Turbo vehicles?
I have been researching, and really I think it is all a matter of what you feel is best. Personally, I will be running mobil1 0w-40 for this winter when I change it in a few weeks then I will be running Rotella T Synthetic 5w40. From my research, I have found that having a higher weight oil will protect better from sheering and heat. So I will run these from now while I am n/a and will continue to when I am boosted. Only downside to running a heavier weight is lower fuel economy and you might loose a tiny bit of power as it is harder for the engine to rotate through it. Research, get on bobistheoilguy.com, and find out what would be best for you
There are lots of opinions on this but I prefer 5w30 for Mid Atlantic winters and 10w30 for summer. I don't like 0w** oils because of the thin base stock nor do I like large viscosity ranges like 5w40 because oils use polymers to acheive multi-viscosity grades. The wider the range, the more polymers and polymers can break down and create sludge. If I ran my car harder I might consider 10w40 or 15w40 in the summer. I run nothing but full synthetic in my car but I run nothing but "non-energy conserving" dino 15w40 in my V-twin motorcycle because of the wet-clutch.
my06tc
Jun 25, 2015 12:18 AM
