piece above license plate
Old Feb 23, 2010 | 12:43 PM
dirtyzachattack's Avatar
Default piece above license plate
Hey All - First post here.
My wife and I just bought a 2005 XB last week. Last night was the first time I got to drive it, and low and behold, i broke it already
I was trying to open the hatch, and when i reached underneath to pull the handle, i evidently pulled too hard and the piece of plastic with the handle broke off. It looks fine, but the part just dangles there.
Help! i felt terrible - my wife hasn't had the car for a week, and i already broke it
Old Feb 23, 2010 | 02:28 PM
Sparks_Scion_TRD_Parts's Avatar
Default Rear handle
Here's a link to our site. Just click on the Body & Appearance section and you can check the part there. http://www.trdsparks.com/displaycategory.php
Ken
Old Feb 26, 2010 | 12:35 AM
vintage42's Avatar
Originally Posted by dirtyzachattack
... 2005 XB... I was trying to open the hatch, and when i reached underneath to pull the handle, i evidently pulled too hard and the piece of plastic with the handle broke off....
Some posted this a few years ago. When my handle felt loose, I removed the big cardboard panel on the hatch and tightened it before it broke.
xB Hatch Handle Repair
1 - Remove the inside panel from the rear door by carefully prying the pop-fasteners off.
2 - Remove the two harnesses for the license plate lights at the connectors.
3 - Remove the two 10mm nuts from the studs that hold the lift gate handle.
4 - Block the door so it doesn't close with a rag over the door sill catch and lower the door.
5 - The handle should slide up and off the rear door, not out and away.
You will now see the two studs that the 10mm nuts threaded onto. They are pressed into two plastic stand-offs that is a part of the handle. These stand-offs have very small and inadequate gussets.
6 - What you do now is take two plastic caps from soda bottles and remove the inner seal.
7 - I used a 7/16" drill bit and made a hole in the cap mostly on the side and a little on the top. The stand-off comes off the inside of the handle at an angle so you can't make a hole straight down through the bottle cap. It must be an elliptical hole penetrating the corner of the cap where the top and the ribbed side of the bottle cap meet. When you take the handle off it will make sense.
8 - Test fit over one of the stand-offs and trim to fit. The open side of the cap will rest flush on the backside of the handle.
9. Complete both caps before proceeding.
10 - With a strong, reliable 2-part epoxy, fill each cap and set them in place. Add more epoxy to form a fillet around the outside of the cap. You do not need a lot of epoxy as epoxy in itself is not a structural material necessarily, depending on the kind you use.
11 - Allow the handle to cure and dry for 24 hours! This is essential. There is no shortcut here, no way to speed it up - not even oven-curing.
To reinstall, the handle slides back on to catch the two clips. Put the two nuts back on but do not over-torque. My rule-of-thumb is snug plus 1/8th to 1/4 turn for plastic parts. Reattach the harness (you can't get them wrong), put the rear panel back on and you are finished.
Old Mar 19, 2010 | 09:13 AM
bB2NER's Avatar
Music City Scions
Congrats on the xB. Did you find a replacement part yet?
Old Mar 19, 2010 | 11:18 AM
Big_Bird's Avatar
Wow, first post covered it. Impressed.
I still don't understand why people can't figure out we don't have a handle. We have an electronic trigger that you lightly press and pull up on. Everything else is a plastic garnish.
Old Mar 22, 2010 | 03:31 PM
thanks to all... i bought the chrome license plate piece and replaced it last weekend. it was very easy, and looks really sharp on the car..
UBOW
19
May 25, 2013 08:31 PM
XB2Pilot
Mar 5, 2009 10:01 PM
CsCheatum
Scion tC 1G Aero & Exterior
Mar 1, 2009 11:54 PM
mtaylor
Feb 11, 2009 08:07 PM
WingRider
Jun 20, 2008 12:46 AM
