Cruise Control not Working?
Old Feb 25, 2010 | 04:54 AM
dospod's Avatar
Default Cruise Control not Working?
So Installed my new HU and I get a Check Engine Light , and the passenger air bag light came on.
To make things short I redid the install today , and passenger air bag light turned off , but I still have the Check Engine Light , and Cruise Control does not work.
The light that says cruise comes on but will not set at any speed. I do not have a warranty , and will probably get killed with fees if I take it in to the dealership.
Any suggestions?
__________________
Old Feb 25, 2010 | 02:56 PM
b52hDUNN's Avatar
check all of your fuses.
Old Feb 25, 2010 | 05:29 PM
rickbreitenfeldt's Avatar
I have to agree check connections and fuses. Did you unhook the battery? I so you may have to reset the system like we had to on our auto windows.
Old Feb 25, 2010 | 08:32 PM
dospod's Avatar
I got the warning read and it was error code p500 which is the vss wire hmm I researched and it seems sometimes peoples speedometer will not work when this error is thrown, and my speedo still works. Tried resetting the ecu by unplugging the negative battery terminal and it still works. I hope its not to hard or expensive to fix
Old Feb 26, 2010 | 12:41 AM
dospod's Avatar
I did get the the scan done at Autozone, my car is throwing error code P0500.
__________________
Old Dec 10, 2011 | 08:05 PM
garabaldy's Avatar
I'm having the same problem after installing a new motor and a APR X-1 piggy back , Did you find the problem? Where is the Vehicle Speed Sensor?
Old Dec 17, 2011 | 12:09 AM
volcomgirl101's Avatar
My Cruise Control isn't working either. I just bought a 2006 Scion xA and it came with the Cruise Control.
Sometimes the light turns on, sometimes it doesn't. But even when the light is on, it doesn't set a speed.
____
Old Dec 17, 2011 | 08:43 AM
DeAnzaJig's Avatar
The reason why you are experiencing these problems is because a lot of head units use the vss wire for a navigation unit, or some other accessory. Im guessing the op either did not have that particular wire connected correctly, had a short in that wire, or popped the fuse.
A bad vss (variable speed sensor) connection would lead to improper spedometer readings, and no cruise control.
With the x1, did you hardwire it or is it a pnp harness?
Old Dec 17, 2011 | 05:07 PM
I didnt wire it. I just bought it that way, so I cant answer that question. I can tell you though I'm pretty sure its the Rostra cruise control.
Old Dec 26, 2011 | 04:21 AM
garabaldy's Avatar
The X-1 is using a PnP
Tkirk
Scion xD Drivetrain & Power
15
Jan 23, 2024 07:45 PM
sberk06
Scion tC 2G ICE & Interior
20
Jun 8, 2012 03:04 AM
acewheels12
Oct 25, 2011 03:04 PM
skimbob2
Mar 13, 2007 04:44 PM
fth4life
May 6, 2006 06:53 AM
