tinting tail lights
Old Mar 24, 2010 | 03:06 AM
marcust80's Avatar
Default tinting tail lights
im wondering if its easier to put vinyls on or paint them.
Old Mar 24, 2010 | 03:22 AM
antonics09's Avatar
My suggestion would be the vinyls because if you mess up, you can always take them off. There's a less likely chance something could go wrong. Probably cost less too.
Old Mar 24, 2010 | 04:07 AM
dahuisurfer's Avatar
i painted mine. gives you the option to go as light or as dark as you want. i like the look of paint compared to vinyl, but with vinyl, if you ever get a fix it ticket it'll be way easier to remove compared to paint.
Old Mar 24, 2010 | 04:11 AM
hardknox's Avatar
vinyls requires alot of patience...ALOT of patience..I've done both and liked the painting better. After putting the vinyls on my tails I immediately decided I didn't like em, could just tell it was vinyl. The painting did seem kinda intimidating at first,but it is kinda easy and less stressful imo. Just don't go TOO dark or else your askin for trouble.
Also if using vht, the paint can be taken off using laquer thinner then buffed out to look just like new.
I'd go the paint route,can make it the exact darkness you want and it is removable as well. You will need to clear a day in your schedule if your paintin em though. Both require patience though so be prepared and goodluck whichever you go!
Old Mar 24, 2010 | 04:31 AM
marcust80's Avatar
when painting do you have to remove the bumper to get to the lights?
Old Mar 24, 2010 | 05:30 AM
Murphys_Law's Avatar
please do, its easier you have to wet sand and prep and it cant be done properly on the car, pull the bumper and take the tails out, wet sand them with a scotch-brite pad thoroughly then wipe them with alcohol and do not touch them again with bare hands the oil in your hand will cause them to orange peel, prep them well and wipe them well and use the VHT for the tint spray, do thin even coats lots of them until you get them as dark as you want them, take your time or youll have alot of headache, and i end up buying them on the cheap and redoing them
Old Mar 24, 2010 | 05:40 AM
antonics09's Avatar
^well that's what I mean with paint, you'll have to prep, wet sand, apply several coats, clear coat, and repeat, etc. If you don't do it exactly right, it'll give you a lot of headach. Plus, both sides might turn out differently. Paint might give it a better look, but if you do the vinyl right, it'll be hard to tell the difference. Either way, gl with your project.
Old Mar 24, 2010 | 06:01 AM
definitely pull your bumper off and take the tails off the car. its a lot of sanding, and a lot of time spent waiting in between coats, but its well worth it. i had no idea what i was doing when i decided to paint my tails, but i just went for it and it turned out pretty good. don't be intimidated about painting, if you mess up just remove the paint and start over again. its a learning experience
Old Mar 24, 2010 | 11:17 AM
tcnoob's Avatar
if u do the vinyl u will have wave lines in the light when outside the VHT way is the best to go and u can touch them with your hands it doesnt cause orange peel...if u need a DIY pm i will send u a link..i was scared at first to do my first set...but u can do it..prep prep prep prep then paint lol...if u need help pm me
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
Cadillac15
Jan 29, 2015 07:34 AM
snappe2
Jan 27, 2015 05:29 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
