help with oil feed
Old Mar 27, 2010 | 09:27 AM
Dethbox's Avatar
Default help with oil feed
i am getting really close to being able to bolt up my turbo but im wondering where the best place for the oil feed is. i know there is a spot on the front of the block but is there also one on the back?
Old Mar 27, 2010 | 02:55 PM
Ace83's Avatar
Ronin Scion
the best place is front right on the side (facing the motor) where the stock oil pressure sensor is.. that is the most accessible and easy to trouble shoot should any leaks or problems happen, also doesnt require you a very long feed line
Old Mar 27, 2010 | 03:08 PM
Ace83's Avatar
Ronin Scion
just realized you have the xb1.. then im not sure then, if it has that oil pressure sensor port like the xb2 and tc then you can get it from there
Old Mar 28, 2010 | 06:11 PM
xa007xa's Avatar
that's not any easy spot to troubleshoot in my case. to get to it, i have to remove the intake manifold which is a pain seeing that i have a weapon-r manifold. the first time it leaked, the oil seeped between my clutch disk and flywheel which led to the rapid deterioration of my clutch. second time it leaked (just a few weeks ago) it was because of the cheap-a$$ Greddy union fitting snapped while threaded into the block. Luckily I was able to use an easy-out to get the broken piece out and I had enough threads left on the fitting to reconnect. However, I used pipe dope instead of teflon tape and no more leaks.
You could also try an oil filter sandwich adapter. And I wouldn't recommend that your oil feed line connect to turbo directly. Again, my cheap-a$$ Greddy hose sprung a leak at the banjo fitting and sprayed oil everywhere. I got me some Earl's -4AN fittings and made a 6 inch long stainless steel tube to place in between the hose and the turbo which dissipates the heat much better than a banjo fitting.
Brammi
Nov 13, 2016 03:46 AM
BlackKnight
Sep 15, 2015 06:42 AM
brett561tc
Sep 15, 2015 06:33 AM
michaelclld
Jul 16, 2015 04:32 AM
StxArOne
Jul 13, 2015 06:25 PM
