Types of Wheel Spacers
Old Apr 13, 2010 | 07:15 PM
night87's Avatar
Default Types of Wheel Spacers
There are a lot of threads covering wheel spacers, but I was wondering the types that you guys would prefer.
Here are two examples:
First:
This one, of course, will need some work because everything will have to come off and this will need to be placed behind the stock
Second:
These are a direct bolt on and will need to use the nuts to tighten it. (much easier than the first one)
Which one is preferred?
Also, having 18x8 +40 for all, which spacers will i need to make it flushed (I checked the wheel size thread on SL, but it's outdated)
Old Apr 13, 2010 | 09:46 PM
jonathan110987's Avatar
i like v2
Old Apr 13, 2010 | 10:17 PM
davedavetC's Avatar
v2 is much easier to install. but you have to make sure that there is deep enough holes in the backside of the wheel to house the excess studs depending on what size you go with.
Old Apr 14, 2010 | 12:47 AM
night87's Avatar
hmm..ok
i'm actually trying to go w/ 15mm F and 25mm R
Wheel specs are 18x8 +40
that good enough to make it flush?
Old Apr 14, 2010 | 04:28 AM
davedavetC's Avatar
should be okay wont be crazy flush but it'll look good but remember if you go v2 you have to have holes or "dents" inbetween the bolts holes on the back of your wheels.
Old Apr 14, 2010 | 04:47 AM
WendysOrBust's Avatar
I've been using the 25mm and 20mm V2's for a few years now and so far (knocks on wood) everythings worked great. I used 25mm on the front and 20mm on the rear on the oem 17' wheels and loved how flush it looked. However the 20mm spacer wouldn't work on my Rpf1's because the nuts that hold the spacer in wouldn't sit flush against the Rpf1, the 25mm' worked fine though.
Here is how the old setup looked
0716091915.jpg?t=1271220344
The fronts don't look as flush only because they are at a -2.5 camber while the rears are only at a ~-1
Old Apr 14, 2010 | 03:13 PM
night87's Avatar
ah~ i know what you mean. so those bolts that hold the spacers will need to sit flush behind the aftermarket/stock wheels. Let's see how that goes
Old Apr 14, 2010 | 03:27 PM
Exactly.
Old Apr 15, 2010 | 06:22 AM
DJ08tC's Avatar
so with the bolt on the ones you dont have to run extended studs?
Old Apr 15, 2010 | 06:32 AM
dqlostsoulz's Avatar
nope
Old Apr 15, 2010 | 06:33 AM
DJ08tC's Avatar
then looks like i might run some 15mm with the stock then.
scionlife
371
Jun 2, 2015 11:00 PM
terrye
Jan 25, 2015 05:31 AM
CAtC12
Dec 23, 2014 04:44 PM
avus
14
Aug 6, 2004 09:27 PM
scionara
38
Feb 25, 2004 04:52 AM
