Tail Light problem...Anzo LED hyperblink?!?!
Old May 6, 2010 | 04:52 AM
FLINTstone's Avatar
Default Tail Light problem...Anzo LED hyperblink?!?!
i just recently got a set of anzo taillights and after installing and hooking up the harnesses, all of the LEDs and reverse light work just fine.
the issue im having is that my turn signals now blink rapidly (hyperblink). there was one little harness i didnt find a connection for though and im guessing this little guy is the problem. its a small plug with a black & yellow/green wire running to it. where am i supposed to plug this thing in???
here is a picture of the plug. any advice would be helpful!
Old May 6, 2010 | 05:18 AM
tCtCtC's Avatar
Is the black box still plugged into the light?
Old May 6, 2010 | 05:24 AM
FLINTstone's Avatar
Yep it's plugged in. Everything is plugged
in except that one little plug
Old May 6, 2010 | 05:28 AM
tCtCtC's Avatar
Are you sure? Cause mine hooks up to that.
Old May 6, 2010 | 06:02 AM
FLINTstone's Avatar
The turn signal and brake harness are plugged into black plugs going into the tail light itself. The plug in question is coming out of the middle of the housing...
Old May 6, 2010 | 06:09 AM
FLINTstone's Avatar
judging from this picture i grabbed from ebay i think the set i have is an older one. ive heard you need resistors to stop the turn signals from hyperblinking. this newer set has them and mine dont...
tctctc does yours have a grey box attached somewhere on the tails?
Old May 6, 2010 | 06:13 AM
rangerryda's Avatar
Mine came with two black boxes that look really similar to that. No hyperblink here and going on 3 years now. No burnt LED's either.
Old May 6, 2010 | 06:14 AM
DJ08tC's Avatar
where did you pick these up so i avoid getting them from that place? lol
hope you solve your problem
Old May 6, 2010 | 06:18 AM
FLINTstone's Avatar
i bought them from a member here on the boards. after doing some research i am indeed missing a set of resistor units that plug into the plug im missing!
these are fairly common and i can order them from superbrightleds.com. thanks all for the help and input!
now just wait and see what i have in store for these babies...
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
terrye
Feb 20, 2015 03:27 PM
Cadillac15
Jan 29, 2015 07:34 AM
TheTripleC
Jan 4, 2015 06:46 PM
