front wheel bearings
Old Jun 6, 2010 | 01:04 PM
rustysavage's Avatar
Default front wheel bearings
Hey all I have an 05 with 108k on the clock. I'm about to order up some wheel bearings. I'm wondering if each hub takes one or 2 bearings? Im about to pick up a press!! does any one have an exploded view or a diy pictorial of the hub by chance?
Old Jun 6, 2010 | 10:46 PM
Lester4's Avatar
I just had one replaced at 63,000 miles and I believe it is just one in each wheel.
Old Jun 8, 2010 | 02:47 AM
Fantastic! thanks for the reply. I just bought my press today and will prob order a pair of bearings to do the front wheels. Ill see if I can post a DIY how to for anyone else not wanting to pay for a shop to touch their ride!
Old Jun 8, 2010 | 04:48 AM
frogbox's Avatar
Remember , bearing to steering knuckle then hub to bearing.
They press in from opposite directions.
Don't forget to pull the cir-clip ( you should replace it anyway while in there.)
If you use a slide hammer to pull the hub first it, before removing the steering knuckle, will make it easier. Just bolt it to your lug studs.
Have fun , been there, done that. Took about 4 hours total time from parking to driving.
Old Jun 8, 2010 | 02:57 PM
vintage42's Avatar
Don't all hubs have an inner and outer bearing race to support the hub on the axle? My motorcycles and boat trailer do, and so does my Subaru Forester. So I assume my xB does, too. So that would be an inner and outer bearing, a set of two bearings, for each hub.
Old Jun 8, 2010 | 05:49 PM
frogbox's Avatar
1 ( one) bearing per side. They are sealed so everything is internal.
And inside they are BALL BEARINGS not the roller bearings we are use to.
Old Jun 9, 2010 | 05:53 PM
ok just so i have it right.... one bearing per hub and the hub is pressed on in one direction and the bearing is pressed from the other correct? what size circlip is it so i can pick some up before i begin? any other tips or parts required?
fur_pig
Mar 20, 2020 04:28 PM
Jordly221
Feb 13, 2019 05:29 PM
xdejablu3x
Apr 19, 2017 03:44 PM
zom6iemac
Nov 28, 2014 12:28 PM
JDMxB
13
Dec 23, 2003 04:23 AM
