kinda rough during warmup
Old Feb 24, 2005 | 07:08 AM
sportmaned's Avatar
Default kinda rough during warmup
Well lately i have been noticing something about my car. Not sure if its just recently or its been going on, but it feels like especially when the cars not yet warmed up, and i shift from first to second, in between 2k and 3k rpms, its real rough like its almost like the engine kicks in kinda, hard to explain but something i can compare it to is like loosing traction over a metal sewer cap after its been raining. It hasnt caught my attention till lately, im not slamming the gas either, can anybody explain or have a theory if anythings wrong or is it just cause the car is not warmed up yet? thanks
Old Feb 24, 2005 | 11:41 AM
nchyflyer's Avatar
don't EVER drive your car AT ALL until it's warmed up... just a little tip, just turn it on, and let is sit there for about 5-10 min. then go on your way.
Old Feb 24, 2005 | 01:01 PM
3_IGs's Avatar
I'm not sure what's going on w/ the car...but if it's not completely warmed up (idle @ 800 R's) you may be experiencing a sort of "lurch" after you shift due to a higher idle as part of the engine's warm-up process.
When I drive off in the morning I usually don't need to use the gass pedal between 1st & 2nd because of the slightly higher idle.
As for this advice:
It is contrary to what the owners manual states...
Old Feb 24, 2005 | 05:05 PM
GimpCent's Avatar
I notice that alot too seems as if my driveline is kinda slipping
Old Feb 24, 2005 | 05:22 PM
scoobyroo2002's Avatar
I always warm up my car. It's a habbit. But ones i did drive it cold beacuse i was late for work. I did notice it's hard to shift from 1st to 2nd but you need not really use much of anything beacuse the idles are so high it's pretty much does it all for you.
Old Feb 24, 2005 | 08:21 PM
garfull's Avatar
5-10 mins is a long time imop. i usually would wait untill the temp guage goes gets up to the first tick or up to normal running temp. that only takes up to 3 mins. recently since ive gone past the break in milleage ive drive off after the temp gets past the second tick but do not go past 3k rpm until its at normal running temp.
Old Feb 24, 2005 | 08:47 PM
TurboMe's Avatar
I once jump into my car and took off right away. I was late for work. The car was jerking for about 4 mins before it was running smoothly. ;)
Old Feb 24, 2005 | 08:51 PM
Torydk87's Avatar
mine does that too. I do have an XA which has a completely diff. engine, but it is jerky till the light goes off
Old Feb 24, 2005 | 10:22 PM
Dwnlow1's Avatar
all manual trans do that till there warm!
Old Feb 24, 2005 | 11:43 PM
Priory_of_Scion's Avatar
the automatic wont shift into overdrive when the car is cold. I thought it was a problem with my engine, and I drove a few times with it not warmed up....since i found out the engine doesnt shift until it gets warm, i wait the 5 mins before driving off. even in the middle of the day, ill wait until i see some warmth reappearing on the gague.
Old Feb 24, 2005 | 11:59 PM
sportmaned's Avatar
k thanks guyys for the input, yeah iwas kinda worried cause last week i left the house and went up to 5 k without the car warmed up like right after startup
Old Feb 25, 2005 | 12:39 AM
miraclecreator's Avatar
I once heard from my friend (which has been driving manual only ever since he was 9) He said we need to wait b/c of the lubricant of the ball or something. (B/c when we leave the car out there or for a while, the temp drops down b/c the car is idle, thus the lubricant for shifting gets harden/frozen.) That's why we need to wait till it gets warm up and melt down?
Old Feb 25, 2005 | 01:28 AM
dex's Avatar
dex
you should warm the car up under load (driving). when the car is idling the motor doesnt get alot of lubrication which is even worse when the oil is cold. its the revs that destroy a cold motor. so you should start driving right after you start the car but keep the revs low until its at operating temperature.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
BlingSlade
Oct 19, 2016 12:39 AM
mikeac
Sep 15, 2015 03:24 PM
Andreas24
Sep 15, 2015 02:10 PM
