Scion xD ICE & Interior In-car entertainment and electronics...
AVIC D3 problems
Old Jul 11, 2010 | 05:10 PM
mr_slim's Avatar
Default AVIC D3 problems
hey sl,
i recently install the avic, and it has a few problems.
the tach/rpm etc feature on the avic doesn't seem to work it says "not available at this time"
another is that it the gps location is off.
any inputs?
Old Jul 11, 2010 | 06:10 PM
jono06tc's Avatar
Are you positive you hooked up everything correctly?
Old Jul 11, 2010 | 06:20 PM
cobaltbravo's Avatar
If the on screen tach isn't working, might want to double check your speed sensor wire is hooked up properly. I don't know which one it is on the xd, I've only needed it on the tc.
Sent from my Droid using Tapatalk
Old Jul 11, 2010 | 07:23 PM
Carlanga's Avatar
you could always tap it to the pink wire that's on the ac control panel thingy, but I think that's the speed sensor.
I though there was a tach input as well, check it out.
Old Jul 11, 2010 | 08:22 PM
Griever's Avatar
^This definitely. Mine had the same problems your's had and they all went away after I tapped it into the speed sensor wire.
Old Jul 11, 2010 | 11:39 PM
mr_slim's Avatar
oh okays.
i tapped into the speed sensor the one originally hooked to the orginal HU. i might tap into the one on the pass side.
but, i do get a a voltage and a "speed pulse"
also, my antenna is not working
its like not moving, any way to fix that?
Old Jul 12, 2010 | 03:31 PM
Which wire is the speed sensor for the xD? I'm getting a f90bt and self installing.
Old Jul 12, 2010 | 07:20 PM
mr_slim's Avatar
its the purple wire.
haha
i'll take a pic of it today
Old Jul 12, 2010 | 09:58 PM
Id much appreciate it. Also, is the reverse wire down behind the kick panel in our xd like it is in the tc, and if so which one? Not sure if ill get the back up cam but just in case.
Sent from my Droid
thesweetnesss
May 15, 2011 02:41 AM
getaforknjob
Scion tC 1G ICE & Interior
21
Aug 11, 2009 02:24 AM
scionsareok
Jan 31, 2009 11:46 PM
ack154
95
Jan 31, 2009 03:09 PM
1_kLEan_tC
15
Oct 23, 2008 08:05 PM
